Datasheet MAX3088ESA+ - Maxim Даташит ИС — Даташит
Наименование модели: MAX3088ESA+
![]() 55 предложений от 22 поставщиков Приемопередатчик RS422, RS485, 4.75В-5.25В питание, 1 драйвер, NSOIC-8 | |||
MAX3088ESA+ Analog Devices | 459 ₽ | ||
MAX3088ESA+T Maxim | от 723 ₽ | ||
MAX3088ESA Maxim | по запросу | ||
MAX3088ESA+T Maxim | по запросу |
Производитель: Maxim
Описание: ИС
19-1800; Rev 1; 5/06
±15kV ESD-Protected, Fail-Safe, High-Speed (10Mbps), Slew-Rate-Limited RS-485/RS-422 Transceivers MAX3080EMAX3089E
General Description
The MAX3080EMAX3089E are ±15kV electrostatic discharge (ESD)-protected, high-speed transceivers for RS485/RS-422 communication that contain one driver and one receiver.
These devices feature fail-safe circuitry, which guarantees a logic-high receiver output when the receiver inputs are open or shorted. This means that the receiver output will be a logic high if all transmitters on a terminated bus are disabled (high impedance). The MAX3080E/MAX3081E/MAX3082E feature reduced slew-rate drivers that minimize EMI and reduce reflections caused by improperly terminated cables, allowing error-free data transmission up to 115kbps. The MAX3083E/MAX3084E/MAX3085E offer higher driver output slew-rate limits, allowing transmit speeds up to 500kbps. The MAX3086E/MAX3087E/ MAX3088Es' driver slew rates are not limited, making transmit speeds up
