PDF, 211 Кб, Язык: анг., Файл закачен: 14 ноя 2017, Страниц: 16
8-Bit Digital-to-Analog Converter with Two-Wire Interface
TC1320
Features General Description •
• The TC1320 is a serially accessible 8-bit voltage output
digital-to-analog converter (DAC). The DAC produces
an output voltage that ranges from ground to an externally supplied reference voltage. It operates from a single power supply that can range from 2.7V to 5.5V,
making it ideal for a wide range of applications. Built
into the part is a Power-on Reset function that ensures
that the device starts at a known condition. 8-bit Digital-to-Analog Converter
±2 LSB INL
±0.8 LSB DNL
2.7-5.5V Single Supply Operation
Simple SMBus/I2CTM Serial Interface
Low Power: 350A Operation, 0.5A Shutdown
8-Pin SOIC and 8-Pin MSOP Packages Communication with the TC1320 is accomplished via a
simple 2-wire SMBus/I2C™ compatible serial port with
the TC1320 acting as a slave only device. The host can
enable the SHDN bit in the CONFIG register to activate …
