Datasheet Linear Technology LTC2875 — Даташит
Серия | LTC2875 |
В±60V Fault Protected 3.3V or 5V 25kV ESD High Speed CAN Transceiver
LTC2875 - В±60V Fault Protected 3.3V or 5V 25kV ESD High Speed CAN Transceiver
PDF, 304 Кб, Версия: F
![]() 29 предложений от 12 поставщиков Чип интерфейса, LTC2875 - ±60V Fault Protected 3.3V or 5V 25kV ESD High Speed CAN Transceiver | |||
LTC2875IDD#TRPBF Analog Devices | от 75 ₽ | ||
LTC2875IDD#TRPBF Analog Devices | от 186 ₽ | ||
LTC2875IS8 Analog Devices | 505 ₽ | ||
LTC2875IDD#PBF Analog Devices | от 522 ₽ |
LTC2875HDD#PBF | LTC2875HDD#TRPBF | LTC2875HS8#PBF | LTC2875HS8#TRPBF | LTC2875IDD#PBF | LTC2875IDD#TRPBF | LTC2875IS8#PBF | LTC2875IS8#TRPBF | LTC2875MPDD#PBF | LTC2875MPDD#TRPBF | LTC2875MPS8#PBF | LTC2875MPS8#TRPBF | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 |
Корпус | 3x3 DFN-8 | 3x3 DFN-8 | SO-8 | SO-8 | 3x3 DFN-8 | 3x3 DFN-8 | SO-8 | SO-8 | 3x3 DFN-8 | 3x3 DFN-8 | SO-8 | SO-8 |
Код корпуса | DD | DD | S8 | S8 | DD | DD | S8 | S8 | DD | DD | S8 | S8 |
Parameters / Models | LTC2875HDD#PBF | LTC2875HDD#TRPBF | LTC2875HS8#PBF | LTC2875HS8#TRPBF | LTC2875IDD#PBF | LTC2875IDD#TRPBF | LTC2875IS8#PBF | LTC2875IS8#TRPBF | LTC2875MPDD#PBF | LTC2875MPDD#TRPBF | LTC2875MPS8#PBF | LTC2875MPS8#TRPBF |
Demo Boards | DC2063A | DC2063A | DC2063A | DC2063A | DC2063A | DC2063A | DC2063A | DC2063A | DC2063A | DC2063A | DC2063A | DC2063A |
Design Tools | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model |
Drivers | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Экспортный контроль, yes/no | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Function | CAN Transceiver | CAN Transceiver | CAN Transceiver | CAN Transceiver | CAN Transceiver | CAN Transceiver | CAN Transceiver | CAN Transceiver | CAN Transceiver | CAN Transceiver | CAN Transceiver | CAN Transceiver |
H Grade Operating Range, Deg | -40В°C to 125В°C | -40В°C to 125В°C | -40В°C to 125В°C | -40В°C to 125В°C | -40В°C to 125В°C | -40В°C to 125В°C | -40В°C to 125В°C | -40В°C to 125В°C | -40В°C to 125В°C | -40В°C to 125В°C | -40В°C to 125В°C | -40В°C to 125В°C |
MP Grade Operating Range, Deg | -55В°C to 125В°C | -55В°C to 125В°C | -55В°C to 125В°C | -55В°C to 125В°C | -55В°C to 125В°C | -55В°C to 125В°C | -55В°C to 125В°C | -55В°C to 125В°C | -55В°C to 125В°C | -55В°C to 125В°C | -55В°C to 125В°C | -55В°C to 125В°C |
Max Data Rate, Mbps | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
Max Junction Temp, Deg | 125 | 125 | 125 | 125 | 125 | 125 | 125 | 125 | 125 | 125 | 125 | 125 |
Рабочий диапазон температур, °C | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 |
Protocols Supported | CAN | CAN | CAN | CAN | CAN | CAN | CAN | CAN | CAN | CAN | CAN | CAN |
Receivers | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Напряжение питания, В | 3.3, 5 | 3.3, 5 | 3.3, 5 | 3.3, 5 | 3.3, 5 | 3.3, 5 | 3.3, 5 | 3.3, 5 | 3.3, 5 | 3.3, 5 | 3.3, 5 | 3.3, 5 |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: LTC2875 (12)
- Interface > CAN Transceivers | Extended Temperature (H & MP) Interface
