Datasheet PIC18F2320-I/SP - Microchip Даташит 8- бит микроконтроллеры (MCU) 8 Кб 512 RAM 25 I/O — Даташит
Microchip PIC18F2320-I/SP
Наименование модели: PIC18F2320-I/SP
25 предложений от 21 поставщиков
Микросхема Микроконтроллер, Microchip PIC18F2320-I/SP, 8Bit PIC Microcontroller, 40MHz, 256B, 8192B Flash, 28Pin SPDIP
727GS
PIC18F2320-I/SP
от 4.72 ₽
Romstore
Россия, Беларусь
PIC18F2320-I/SP
от 1 180 ₽
Триема
PIC18F2320-I/SP DIP28-300 Microchip
2 730 ₽
PIC18F2320-I/SP, Микроконтроллер 8-Бит, PIC, 40МГц, 8КБ (4Кx16) Flash, c 10-Бит АЦП, 16 I/O [DIP-18]
Fairchild
Производитель: Microchip
Описание: 8- бит микроконтроллеры (MCU) 8 Кб 512 RAM 25 I/O
data sheetСкачать Data Sheet
PIC18F2220/2320/4220/4320 Data Sheet
28/40/44-Pin High-Performance, Enhanced Flash Microcontrollers with 10-Bit A/D and nanoWatt Technology
2003 Microchip Technology Inc.
DS39599C
Note the following details of the code protection feature on Microchip devices: · · Microchip products meet the specification contained in their particular Microchip Data Sheet.
Microchip believes that its family of products is one of the most secure families of its kind on the market today, when used in the intended manner and under normal conditions. There are dishonest and possibly illegal methods used to breach the code protection feature. All of these methods, to our knowledge, require using the Microchip products in a manner outside the operating specifications contained in Microchip's Data Sheets. Most likely, the person doing so is engaged in theft of intellectual property. Microchip is willing to work with the customer who is concerned about the integrity of their code. Neither Microchip nor any
  • Supply Voltage - Max: 5.5 В
  • Supply Voltage - Min: 4.2 В
  • Вид монтажа: Through Hole
  • Встроенный в чип АЦП: да
  • Высота: 3.3 мм
  • Длина: 34.67 мм
  • Доступные аналоговые/цифровые каналы: 10
  • Интерфейс: I2C, SPI, USART
  • Количество линий ввода/вывода: 25
  • Количество таймеров: 5
  • Рабочее напряжение питания: 2 В ... 5.5 В
  • Размер ОЗУ: 512 B
  • Размер ПЗУ данных: 256 B
  • Размер памяти программ: 8 Кб
  • Разрядность АЦП: 10 бит
  • Серия процессора: PIC18
  • Тактовая частота максимальная: 40 МГц
  • Тип корпуса: SPDIP-28
  • Тип памяти программ: Flash
  • Упаковка: Tube
  • Шина данных: 8 бит
  • Ширина: 7.24 мм
  • Ядро: PIC
  • RoHS: да
PIC18F2320I/SP, PIC18F2320 I/SP
На английском языке: Datasheet PIC18F2320-I/SP - Microchip 8- bit Microcontrollers (MCU) 8 Kb 512 RAM 25 I/O
