Datasheet Intersil ISL88732 — Даташит
ПроизводительIntersil
СерияISL88732
Зарядное устройство SMBus Level 2 с режимом Boost
Data Short ISL88732
PDF, 203 Кб, Версия: 24-10-2017, Файл закачен: 19 ноя 2017, Страниц: 2
SMBus Level 2 Battery Charger with Boost Mode
11 предложений от 10 поставщиков
Микросхема Чип управления батареи, Battery Charger 28Pin TQFN EP
ISL88732HRTZ-T
Intersil
220 ₽
ISL88732HRTZ-T
Intersil
220 ₽
ISL88732HRTZ-T
Intersil
220 ₽
ISL88732HRTZ-T
Intersil
от 272 ₽
ISL88732HRTZISL88732HRTZ-T
N12
Корпус28 Ld TQFN28 Ld TQFN T+R
Parameters / ModelsISL88732HRTZISL88732HRTZ-T
Audible NoiseNoNo
Automatic Power Source SelectionNo (Set by Host)No (Set by Host)
Automatic Trickle Charge Typ (V)2.72.7
Battery Charge Voltage (V)1.024 to 19.2 in 16mV Steps1.024 to 19.2 in 16mV Steps
Battery Charge Voltage Adjust (%)16mV steps16mV steps
Battery ChemistryMulti-Cell Li+/PolymerMulti-Cell Li+/Polymer
Battery Leakage Current Max (μA)2 (DCIN=0V, No System Load)2 (DCIN=0V, No System Load)
Battery Leakage Current Max (ОјA)2 (DCIN=0V, No System Load)2 (DCIN=0V, No System Load)
Charge Current Limit Accuracy (%)В±3В±3
Charging Voltage Accuracy Max (%)В±0.5В±0.5
DC Adapter DetectionNo (Set by Host)No (Set by Host)
DescriptionSMBus Level 2 Battery Charger with Boost ModeSMBus Level 2 Battery Charger with Boost Mode
Input Current Limit Accuracy (%)В±3В±3
Max Duty Cycle (%)99.699.6
Рабочий диапазон температурот -10 до 100от -10 до 100
Peak Temp260°C260°C
Qualification LevelStandardStandard
Switching Frequency (typ) (kHz)400400
Thermal Shutdown (В°C)150 °C150 °C
TopologyFixed Frequency Synchronous BuckFixed Frequency Synchronous Buck
Trickle Charge Current Limit Accuracy (%)64mA to 220mA64mA to 220mA
VIN (max) (V)2222
VIN (min) (V)88
RoHSСовместимСовместим
Серия: ISL88732 (2)
  • Power Management > Battery Management Systems > Multiple Cell Battery Chargers
На английском языке: Datasheet Intersil ISL88732
