Datasheet Intersil ISL88733 — Даташит
Производитель | Intersil |
Серия | ISL88733 |
Зарядное устройство SMBus уровня 2
![]() 15 предложений от 12 поставщиков Микросхема Чип управления батареи, Battery Charger 28Pin TQFN EP | |||
ISL88733HRTZ-T Intersil | 243 ₽ | ||
ISL88733HRTZ-T Renesas | 291 ₽ | ||
ISL88733HRTZ Intersil | по запросу |
ISL88733HRTZ | ISL88733HRTZ-T | |
N | 1 | 2 |
Корпус | 28 Ld TQFN | 28 Ld TQFN T+R |
Parameters / Models | ISL88733HRTZ | ISL88733HRTZ-T |
Audible Noise | No | No |
Automatic Power Source Selection | No (Set by Host) | No (Set by Host) |
Automatic Trickle Charge Typ (V) | 2.7 | 2.7 |
Battery Charge Voltage (V) | 1.024 to 19.2 in 16mV Steps | 1.024 to 19.2 in 16mV Steps |
Battery Charge Voltage Adjust (%) | 16mV steps | 16mV steps |
Battery Chemistry | Multi-Cell Li+/Polymer | Multi-Cell Li+/Polymer |
Battery Leakage Current Max (μA) | 2 (DCIN=0V, No System Load) | 2 (DCIN=0V, No System Load) |
Battery Leakage Current Max (ОјA) | 2 (DCIN=0V, No System Load) | 2 (DCIN=0V, No System Load) |
Charge Current Limit Accuracy (%) | В±3 | В±3 |
Charging Voltage Accuracy Max (%) | В±0.5 | В±0.5 |
DC Adapter Detection | No (Set by Host) | No (Set by Host) |
Description | SMBus Level 2 Battery Charger | SMBus Level 2 Battery Charger |
Input Current Limit Accuracy (%) | В±4 | В±4 |
Max Duty Cycle (%) | 99.6 | 99.6 |
Рабочий диапазон температур | от -10 до 100 | от -10 до 100 |
Peak Temp | 260°C | 260°C |
Qualification Level | Standard | Standard |
Switching Frequency (typ) (kHz) | 400 | 400 |
Thermal Shutdown (В°C) | 150 °C | 150 °C |
Topology | Fixed Frequency Synchronous Buck | Fixed Frequency Synchronous Buck |
Trickle Charge Current Limit Accuracy (%) | 64mA to 220mA | 64mA to 220mA |
VIN (max) (V) | 22 | 22 |
VIN (min) (V) | 8 | 8 |
Серия: ISL88733 (2)
- Power Management > Battery Management Systems > Multiple Cell Battery Chargers
