Datasheet Intersil ISL9520HRTZ-T — Даташит
| Производитель | Intersil |
| Серия | ISL9520 |
| Модель | ISL9520HRTZ-T |
Узкий регулятор напряжения постоянного тока/зарядное устройство с интерфейсом SMBus
Купить ISL9520HRTZ-T на РадиоЛоцман.Цены — от 33 до 1 468 ₽10 предложений от 10 поставщиков Микросхема Чип управления батареи, Battery Charger Li-Polymer 2.5V to 19V 28Pin TQFN EP T/R | |||
| ISL9520HRTZ-T Renesas | 291 ₽ | ||
| ISL9520HRTZ-T Renesas | по запросу | ||
| Корпус | 28 Ld TQFN T+R |
| Audible Noise | No |
| Automatic Power Source Selection | No |
| Automatic Trickle Charge Typ (V) | 4.7 |
| Battery Charge Voltage (V) | 2.5V to 19V in 16mV Steps |
| Battery Charge Voltage Adjust (%) | 16mV steps |
| Battery Chemistry | Multi-Cell Li+/Polymer |
| Battery Leakage Current Max (μA) | 25 (DCIN=0V, No System Load) |
| Battery Leakage Current Max (ОјA) | 25 (DCIN=0V, No System Load) |
| Charge Current Limit Accuracy (%) | В±3 |
| Charging Voltage Accuracy Max (%) | В±0.5 |
| DC Adapter Detection | Yes |
| Description | Narrow VDC Regulator/Charger with SMBus Interface |
| Input Current Limit Accuracy (%) | В±3 |
| Рабочий диапазон температур | от -10 до 100 |
| Peak Temp | 260°C |
| Switching Frequency (typ) (kHz) | 400 |
| Thermal Shutdown (В°C) | 150 °C |
| Topology | Variable Frequency Synchronous Buck |
| Trickle Charge Current Limit Accuracy (%) | 256mA |
| VIN (max) (V) | 22 |
| VIN (min) (V) | 9 |
Серия: ISL9520 (2)
- ISL9520HRTZ ISL9520HRTZ-T
- Power Management > Battery Management Systems > Multiple Cell Battery Chargers
ISL9520HRTZT, ISL9520HRTZ T
