Линейка продуктов KEEN SIDE
Datasheet Intersil ISL9519HRTZ — Даташит
ПроизводительIntersil
СерияISL9519
МодельISL9519HRTZ
Узкий регулятор напряжения постоянного тока/зарядное устройство с интерфейсом SMBus
ISL9519 Data Short
PDF, 159 Кб, Версия: 30-10-2017
Микросхема Чип управления батареи, Narrow VDC Regulator and Charger 28Pin TQFN EP T/R
ISL9519HRTZ-T
Intersil
197 ₽
ISL9519HRTZ-T
Renesas
от 980 ₽
ЗУМ-СМД
ISL9519HRTZ
Intersil
Контест
ISL9519HRTZ-T
Intersil
Корпус28 Ld TQFN
Audible NoiseNo
Automatic Power Source SelectionYes
Automatic Trickle Charge Typ (V)4.7
Battery Charge Voltage (V)2V to 16.3V in 16mV Steps
Battery Charge Voltage Adjust (%)16mV steps
Battery ChemistryMulti-Cell Li+/Polymer
Battery Leakage Current Max (μA)25 (DCIN=0V, No System Load)
Battery Leakage Current Max (ОјA)25 (DCIN=0V, No System Load)
Charge Current Limit Accuracy (%)В±3
Charging Voltage Accuracy Max (%)В±0.5
DC Adapter DetectionYes
DescriptionNarrow VDC Regulator/Charger with SMBus Interface
Input Current Limit Accuracy (%)В±3
Max Duty Cycle (%)99
Рабочий диапазон температурот -40 до 100
Peak Temp260°C
Qualification LevelStandard
Switching Frequency (typ) (kHz)400
Thermal Shutdown (В°C)150 °C
TopologyVariable Frequency Synchronous Buck
Trickle Charge Current Limit Accuracy (%)166A to 346mA
VIN (max) (V)22
VIN (min) (V)4.5
Серия: ISL9519 (4)
  • Power Management > Battery Management Systems > Multiple Cell Battery Chargers
На английском языке: Datasheet Intersil ISL9519HRTZ
