Datasheet Intersil ISL9519HRTZ-T — Даташит
Производитель | Intersil |
Серия | ISL9519 |
Модель | ISL9519HRTZ-T |
Узкий регулятор напряжения постоянного тока/зарядное устройство с интерфейсом SMBus
![]() 22 предложений от 14 поставщиков Микросхема Чип управления батареи, Narrow VDC Regulator and Charger 28Pin TQFN EP T/R | |||
ISL9519HRTZ-T | 58 ₽ | ||
ISL9519HRTZ-T Renesas | от 158 ₽ | ||
ISL9519HRTZ-T Intersil | 171 ₽ | ||
ISL9519HRTZ-T Intersil | по запросу |
Корпус | 28 Ld TQFN T+R |
Audible Noise | No |
Automatic Power Source Selection | Yes |
Automatic Trickle Charge Typ (V) | 4.7 |
Battery Charge Voltage (V) | 2V to 16.3V in 16mV Steps |
Battery Charge Voltage Adjust (%) | 16mV steps |
Battery Chemistry | Multi-Cell Li+/Polymer |
Battery Leakage Current Max (μA) | 25 (DCIN=0V, No System Load) |
Battery Leakage Current Max (ОјA) | 25 (DCIN=0V, No System Load) |
Charge Current Limit Accuracy (%) | В±3 |
Charging Voltage Accuracy Max (%) | В±0.5 |
DC Adapter Detection | Yes |
Description | Narrow VDC Regulator/Charger with SMBus Interface |
Input Current Limit Accuracy (%) | В±3 |
Max Duty Cycle (%) | 99 |
Рабочий диапазон температур | от -40 до 100 |
Peak Temp | 260°C |
Switching Frequency (typ) (kHz) | 400 |
Thermal Shutdown (В°C) | 150 °C |
Topology | Variable Frequency Synchronous Buck |
Trickle Charge Current Limit Accuracy (%) | 166A to 346mA |
VIN (max) (V) | 22 |
VIN (min) (V) | 4.5 |
Серия: ISL9519 (4)
- ISL9519HRTZ ISL9519HRTZ-T ISL9519IRTZ ISL9519IRTZ-T
- Power Management > Battery Management Systems > Multiple Cell Battery Chargers
ISL9519HRTZT, ISL9519HRTZ T
