Datasheet Intersil ISL9519 — Даташит
ПроизводительIntersil
СерияISL9519
Узкий регулятор напряжения постоянного тока/зарядное устройство с интерфейсом SMBus
ISL9519 Data Short
PDF, 159 Кб, Версия: 30-10-2017
24 предложений от 21 поставщиков
Микросхема Чип управления батареи, Narrow VDC Regulator and Charger 28Pin TQFN EP T/R
ISL9519CHRZ
Intersil
68 ₽
ISL9519HRTZ
Renesas
95 ₽
ISL9519HRTZ-T
Intersil
ISL9519IRTZ-T
Intersil
ISL9519HRTZISL9519HRTZ-TISL9519IRTZISL9519IRTZ-T
N1234
Корпус28 Ld TQFN28 Ld TQFN T+R28 Ld TQFN28 Ld TQFN T+R
Parameters / ModelsISL9519HRTZISL9519HRTZ-TISL9519IRTZISL9519IRTZ-T
Audible NoiseNoNoNoNo
Automatic Power Source SelectionYesYesYesYes
Automatic Trickle Charge Typ (V)4.74.74.74.7
Battery Charge Voltage (V)2V to 16.3V in 16mV Steps2V to 16.3V in 16mV Steps2V to 16.3V in 16mV Steps2V to 16.3V in 16mV Steps
Battery Charge Voltage Adjust (%)16mV steps16mV steps16mV steps16mV steps
Battery ChemistryMulti-Cell Li+/PolymerMulti-Cell Li+/PolymerMulti-Cell Li+/PolymerMulti-Cell Li+/Polymer
Battery Leakage Current Max (μA)25 (DCIN=0V, No System Load)25 (DCIN=0V, No System Load)25 (DCIN=0V, No System Load)25 (DCIN=0V, No System Load)
Battery Leakage Current Max (ОјA)25 (DCIN=0V, No System Load)25 (DCIN=0V, No System Load)25 (DCIN=0V, No System Load)25 (DCIN=0V, No System Load)
Charge Current Limit Accuracy (%)В±3В±3В±3В±3
Charging Voltage Accuracy Max (%)В±0.5В±0.5В±0.5В±0.5
DC Adapter DetectionYesYesYesYes
DescriptionNarrow VDC Regulator/Charger with SMBus InterfaceNarrow VDC Regulator/Charger with SMBus InterfaceNarrow VDC Regulator/Charger with SMBus InterfaceNarrow VDC Regulator/Charger with SMBus Interface
Input Current Limit Accuracy (%)В±3В±3В±3В±3
Max Duty Cycle (%)99999999
Рабочий диапазон температурот -40 до 100от -40 до 100от -40 до 100от -40 до 100
Peak Temp260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandard
Switching Frequency (typ) (kHz)400400400400
Thermal Shutdown (В°C)150 °C150 °C150 °C150 °C
TopologyVariable Frequency Synchronous BuckVariable Frequency Synchronous BuckVariable Frequency Synchronous BuckVariable Frequency Synchronous Buck
Trickle Charge Current Limit Accuracy (%)166A to 346mA166A to 346mA166A to 346mA166A to 346mA
VIN (max) (V)22222222
VIN (min) (V)4.54.54.54.5
RoHSСовместимСовместимСовместимСовместим
  • Power Management > Battery Management Systems > Multiple Cell Battery Chargers
На английском языке: Datasheet Intersil ISL9519
