Datasheet Intersil ISL6334A — Даташит
ПроизводительIntersil
СерияISL6334A
VR11.1, 4-фазный ШИМ-контроллер с повышенной эффективностью при малой нагрузке и контролем тока нагрузки
ISL6334, ISL6334A Datasheet
PDF, 770 Кб, Версия: 2017-12-05
VR11.1, 4-Phase PWM Controller with Light Load Efficiency Enhancement and Load Current Monitoring
ISL6334A
Intersil
ISL6334ACRZISL6334ACRZ-TISL6334AIRZISL6334AIRZ-T
N1234
Корпус40 Ld QFN40 Ld QFN T+R40 Ld QFN40 Ld QFN T+R
Parameters / ModelsISL6334ACRZISL6334ACRZ-TISL6334AIRZISL6334AIRZ-T
ApplicationsVR11.1VR11.1VR11.1VR11.1
DescriptionVR11.1, 4-Phase PWM Controller with Enhanced Light Load Efficiency and Load Current MonitoringVR11.1, 4-Phase PWM Controller with Enhanced Light Load Efficiency and Load Current MonitoringVR11.1, 4-Phase PWM Controller with Enhanced Light Load Efficiency and Load Current MonitoringVR11.1, 4-Phase PWM Controller with Enhanced Light Load Efficiency and Load Current Monitoring
DroopYesYesYesYes
IOUT (max) (A)130130130130
Integrated MOSFET Driver(s)YesYesYesYes
Max # of Outputs1111
Max # of Phases4444
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandard
VBIAS (V)4.75 to 5.254.75 to 5.254.75 to 5.254.75 to 5.25
VIDYesYesYesYes
VIN (max) (V)12121212
VIN (min) (V)3333
VOUT (max) (V)1.61.61.61.6
VOUT (min) (V)0.50.50.50.5
RoHSСовместимСовместимСовместимСовместим
ISL6334
  • Power Management > Computing Power VRM/IMVP > Multiphase Controllers
На английском языке: Datasheet Intersil ISL6334A
