Datasheet Intersil ISL6327A — Даташит
ПроизводительIntersil
СерияISL6327A
VR11 6-фазный ШИМ-контроллер с 8-битным VID и дифференциальным индуктором DCR или резисторным датчиком тока
ISL6327A Datasheet
PDF, 684 Кб, Версия: 2017-12-05
Enhanced 6-Phase PWM Controller with 8-Bit VID Code and Differential Inductor DCR or Resistor Current Sensing
ISL6327A
Intersil
ISL6327ACRZISL6327ACRZ-TISL6327AIRZISL6327AIRZ-T
N1234
Корпус48 Ld QFN48 Ld QFN T+R48 Ld QFN48 Ld QFN T+R
Parameters / ModelsISL6327ACRZISL6327ACRZ-TISL6327AIRZISL6327AIRZ-T
ApplicationsVR11 Workstations, ServersVR11 Workstations, ServersVR11 Workstations, ServersVR11 Workstations, Servers
DescriptionVR11 6-Phase PWM Controller with 8-Bit VID and Differential Inductor DCR or Resistor Current SensingVR11 6-Phase PWM Controller with 8-Bit VID and Differential Inductor DCR or Resistor Current SensingVR11 6-Phase PWM Controller with 8-Bit VID and Differential Inductor DCR or Resistor Current SensingVR11 6-Phase PWM Controller with 8-Bit VID and Differential Inductor DCR or Resistor Current Sensing
DroopYesYesYesYes
IOUT (max) (A)200200200200
Integrated MOSFET Driver(s)YesYesYesYes
Max # of Outputs1111
Max # of Phases6666
Рабочий диапазон температурот 0 до 70от 0 до 70от 0 до 70от 0 до 70
Peak Temp260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandard
VBIAS (V)4.75 to 5.254.75 to 5.254.75 to 5.254.75 to 5.25
VIDYesYesYesYes
VIN (max) (V)12121212
VIN (min) (V)3333
VOUT (max) (V)1.61.61.61.6
VOUT (min) (V)0.50.50.50.5
RoHSСовместимСовместимСовместимСовместим
  • Power Management > Computing Power VRM/IMVP > Multiphase Controllers
На английском языке: Datasheet Intersil ISL6327A
