Datasheet Intersil HA-5002 — Даташит
| Производитель | Intersil |
| Серия | HA-5002 |
110 МГц, высокая скорость нарастания напряжения, большой буфер выходного тока
9 предложений от 9 поставщиков Monolithic, Wideband, High Slew Rate, High Output Current Buffer  | |||
| HA5002-9 | по запросу | ||
| HA5002-5/-9 | по запросу | ||
| HA5002-5(HA7.A3)(HA3-50 | по запросу | ||
| HA5002-2/883 Atmel  | по запросу | ||
| HA2-5002-2ZR5254 | HA4P5002-5Z | HA9P5002-5Z | HA9P5002-9Z | |
| N | 1 | 2 | 3 | 4 |
| Корпус | 8 Ld CAN | 20 Ld PLCC | 8 Ld SOIC | 8 Ld SOIC |
| Parameters / Models | HA2-5002-2ZR5254 | HA4P5002-5Z | HA9P5002-5Z | HA9P5002-9Z |
| Полоса частот | 110 MHz | 110 MHz | 110 MHz | 110 MHz |
| Количество каналов | 1 | 1 | 1 | 1 |
| Description | 110MHz, High Slew Rate, High Output Current Buffer | 110MHz, High Slew Rate, High Output Current Buffer | 110MHz, High Slew Rate, High Output Current Buffer | 110MHz, High Slew Rate, High Output Current Buffer |
| Enable | No | No | No | No |
| Gain AV (min) | 0.995 | 0.995 | 0.995 | 0.995 |
| IBIAS | 2 µA | 2 µA | 2 µA | 2 µA |
| IBIAS (max) | 7 µA | 7 µA | 7 µA | 7 µA |
| IOUT | 200 mA | 200 mA | 200 mA | 200 mA |
| IS (per amp) | 8.3 mA | 8.3 mA | 8.3 mA | 8.3 mA |
| Рабочий диапазон температур | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 |
| Output Headroom | 1.5 V | 1.5 V | 1.5 V | 1.5 V |
| PSRR | 64 dB | 64 dB | 64 dB | 64 dB |
| Peak Temp | 250°C | 260°C | 260°C | |
| Qualification Level | Standard | Standard | Standard | Standard |
| Rail-to-Rail Input | No | No | No | No |
| Rail-to-Rail Output | No | No | No | No |
| Скорость нарастания | 1300 V/μs | 1300 V/μs | 1300 V/μs | 1300 V/μs |
| THD | 86 dB | 86 dB | 86 dB | 86 dB |
| Thermal Shutdown | No | No | No | No |
| Topology | Fixed Gain | Fixed Gain | Fixed Gain | Fixed Gain |
| VOS (max) | 5 mV | 5 mV | 5 mV | 5 mV |
| VOUT | 27 V | 27 V | 27 V | 27 V |
| VS (max) | 40 V | 40 V | 40 V | 40 V |
| VS (min) | 10 V | 10 V | 10 V | 10 V |
| RoHS | Совместим | Совместим | Совместим | Совместим |
Серия: HA-5002 (4)
- Amplifiers & Buffers > All Amplifiers > Amplifiers
