Datasheet Intersil ISL28006 — Даташит
| Производитель | Intersil |
| Серия | ISL28006 |
Микромощный усилитель тока с рельсовым входом и выходным напряжением
| ISL28006FH100Z-T7 | ISL28006FH100Z-T7A | ISL28006FH20Z-T7 | ISL28006FH20Z-T7A | ISL28006FH50Z-T7 | ISL28006FH50Z-T7A | ISL28006FHADJZ-T7 | ISL28006FHADJZ-T7A | |
| N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
| Корпус | 5 Ld SOT T+R | 5 Ld SOT T+R | 5 Ld SOT T+R | 5 Ld SOT T+R | 5 Ld SOT T+R | 5 Ld SOT T+R | 6 Ld SOT T+R | 6 Ld SOT T+R |
| Parameters / Models | ISL28006FH100Z-T7 | ISL28006FH100Z-T7A | ISL28006FH20Z-T7 | ISL28006FH20Z-T7A | ISL28006FH50Z-T7 | ISL28006FH50Z-T7A | ISL28006FHADJZ-T7 | ISL28006FHADJZ-T7A |
| Alternatives | See "Digital Power Monitoring" | See "Digital Power Monitoring" | See "Digital Power Monitoring" | See "Digital Power Monitoring" | See "Digital Power Monitoring" | See "Digital Power Monitoring" | See "Digital Power Monitoring" | See "Digital Power Monitoring" |
| CMRR | 115 dB | 115 dB | 115 dB | 115 dB | 115 dB | 115 dB | 115 dB | 115 dB |
| Common Mode Input Range (max) | 28 V | 28 V | 28 V | 28 V | 28 V | 28 V | 28 V | 28 V |
| Common Mode Input Range (min) | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V |
| Коэффициент подавления синфазного сигнала | 115 dB | 115 dB | 115 dB | 115 dB | 115 dB | 115 dB | 115 dB | 115 dB |
| Description | Micropower, Rail to Rail Input Current Sense Amplifier with Voltage Output | Micropower, Rail to Rail Input Current Sense Amplifier with Voltage Output | Micropower, Rail to Rail Input Current Sense Amplifier with Voltage Output | Micropower, Rail to Rail Input Current Sense Amplifier with Voltage Output | Micropower, Rail to Rail Input Current Sense Amplifier with Voltage Output | Micropower, Rail to Rail Input Current Sense Amplifier with Voltage Output | Micropower, Rail to Rail Input Current Sense Amplifier with Voltage Output | Micropower, Rail to Rail Input Current Sense Amplifier with Voltage Output |
| Gain (V/V) | 20, 50, 100, Adj | 20, 50, 100, Adj | 20, 50, 100, Adj | 20, 50, 100, Adj | 20, 50, 100, Adj | 20, 50, 100, Adj | 20, 50, 100, Adj | 20, 50, 100, Adj |
| IS (per amp) | 0.05 mA | 0.05 mA | 0.05 mA | 0.05 mA | 0.05 mA | 0.05 mA | 0.05 mA | 0.05 mA |
| Рабочий диапазон температур | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 |
| Output | Voltage | Voltage | Voltage | Voltage | Voltage | Voltage | Voltage | Voltage |
| PSRR | 105 dB | 105 dB | 105 dB | 105 dB | 105 dB | 105 dB | 105 dB | 105 dB |
| Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C |
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
| VOS (max) | 0.25 mV | 0.25 mV | 0.25 mV | 0.25 mV | 0.25 mV | 0.25 mV | 0.25 mV | 0.25 mV |
| VS (max) | 28 V | 28 V | 28 V | 28 V | 28 V | 28 V | 28 V | 28 V |
| VS (min) | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V |
| RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ISL28006 (8)
- Amplifiers & Buffers > All Amplifiers > Current Sense Amplifiers
