Datasheet Intersil ISL28005 — Даташит
ПроизводительIntersil
СерияISL28005
Микромощный усилитель измерения тока с размахом входного сигнала и выходным напряжением
ISL28005 Datasheet
PDF, 1.1 Мб, Версия: 2017-10-20
Усилители считывания тока ISL28005FH20Z MICROP WR CUR SENSE AMP W/
ISL28005_11
Intersil
МосЧип
ISL28005
Intersil
ISL28005FH100Z-T7ISL28005FH100Z-T7AISL28005FH20Z-T7ISL28005FH20Z-T7AISL28005FH50Z-T7ISL28005FH50Z-T7A
N123456
Корпус5 Ld SOT T+R5 Ld SOT T+R5 Ld SOT T+R5 Ld SOT T+R5 Ld SOT T+R5 Ld SOT T+R
Parameters / ModelsISL28005FH100Z-T7ISL28005FH100Z-T7AISL28005FH20Z-T7ISL28005FH20Z-T7AISL28005FH50Z-T7ISL28005FH50Z-T7A
AlternativesSee "Digital Power Monitoring"See "Digital Power Monitoring"See "Digital Power Monitoring"See "Digital Power Monitoring"See "Digital Power Monitoring"See "Digital Power Monitoring"
CMRR115 dB115 dB115 dB115 dB115 dB115 dB
Common Mode Input Range (max)28 V28 V28 V28 V28 V28 V
Common Mode Input Range (min)0 V0 V0 V0 V0 V0 V
Коэффициент подавления синфазного сигнала115 dB115 dB115 dB115 dB115 dB115 dB
DescriptionMicropower, Rail-to-Rail Input Current Sense Amplifier with Voltage OutputMicropower, Rail-to-Rail Input Current Sense Amplifier with Voltage OutputMicropower, Rail-to-Rail Input Current Sense Amplifier with Voltage OutputMicropower, Rail-to-Rail Input Current Sense Amplifier with Voltage OutputMicropower, Rail-to-Rail Input Current Sense Amplifier with Voltage OutputMicropower, Rail-to-Rail Input Current Sense Amplifier with Voltage Output
Gain (V/V)20, 50, 10020, 50, 10020, 50, 10020, 50, 10020, 50, 10020, 50, 100
IS (per amp)0.05 mA0.05 mA0.05 mA0.05 mA0.05 mA0.05 mA
Рабочий диапазон температурот -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125
OutputVoltageVoltageVoltageVoltageVoltageVoltage
PSRR105 dB105 dB105 dB105 dB105 dB105 dB
Peak Temp260°C260°C260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandard
VOS (max)0.5 mV0.5 mV0.5 mV0.5 mV0.5 mV0.5 mV
VS (max)28 V28 V28 V28 V28 V28 V
VS (min)2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V
RoHSСовместимСовместимСовместимСовместимСовместимСовместим
  • Amplifiers & Buffers > All Amplifiers > Current Sense Amplifiers
На английском языке: Datasheet Intersil ISL28005
