Datasheet Intersil EL8302 — Даташит
ПроизводительIntersil
СерияEL8302
Усилитель Rail-to-Rail 500 МГц
EL8302 Datasheet
PDF, 1.2 Мб, Версия: 2017-10-09
25 предложений от 22 поставщиков
EL8302IS
Intersil
43 ₽
EL8302ISZ-T7
Intersil
EL8302IUZ-T7
Intersil
TradeElectronics
EL8302ES
Intersil
EL8302ISEL8302IS-T13EL8302IS-T7EL8302ISZEL8302ISZ-T13EL8302ISZ-T7EL8302IUEL8302IU-T13EL8302IU-T7EL8302IUZEL8302IUZ-T13EL8302IUZ-T7
N123456789101112
Корпус16 Ld SOIC16 Ld SOIC T+R16 Ld SOIC T+R16 Ld SOIC16 Ld SOIC T+R16 Ld SOIC T+R16 Ld QSOP16 Ld QSOP T+R16 Ld QSOP T+R16 Ld QSOP16 Ld QSOP T+R16 Ld QSOP T+R
Parameters / ModelsEL8302ISEL8302IS-T13EL8302IS-T7EL8302ISZEL8302ISZ-T13EL8302ISZ-T7EL8302IUEL8302IU-T13EL8302IU-T7EL8302IUZEL8302IUZ-T13EL8302IUZ-T7
2nd Harmonic-74 dB-74 dB-74 dB-74 dB-74 dB-74 dB-74 dB-74 dB-74 dB-74 dB-74 dB-74 dB
3rd Harmonic-87 dB-87 dB-87 dB-87 dB-87 dB-87 dB-87 dB-87 dB-87 dB-87 dB-87 dB-87 dB
AVOL90 dB90 dB90 dB90 dB90 dB90 dB90 dB90 dB90 dB90 dB90 dB90 dB
Полоса частот500 MHz500 MHz500 MHz500 MHz500 MHz500 MHz500 MHz500 MHz500 MHz500 MHz500 MHz500 MHz
Количество каналов333333333333
Коэффициент подавления синфазного сигнала95 dB95 dB95 dB95 dB95 dB95 dB95 dB95 dB95 dB95 dB95 dB95 dB
Description500MHz Rail-to-Rail Amplifier500MHz Rail-to-Rail Amplifier500MHz Rail-to-Rail Amplifier500MHz Rail-to-Rail Amplifier500MHz Rail-to-Rail Amplifier500MHz Rail-to-Rail Amplifier500MHz Rail-to-Rail Amplifier500MHz Rail-to-Rail Amplifier500MHz Rail-to-Rail Amplifier500MHz Rail-to-Rail Amplifier500MHz Rail-to-Rail Amplifier500MHz Rail-to-Rail Amplifier
Diff Gain (%)0.010.010.010.010.010.010.010.010.010.010.010.01
Diff Phase (В°)0.010.010.010.010.010.010.010.010.010.010.010.01
Distortion Conditions2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz
EnableYesYesYesYesYesYesYesYesYesYesYesYes
Gain AV (min)111111111111
IBIAS6 μA6 μA6 μA6 μA6 μA6 μA6 µA6 µA6 µA6 μA6 μA6 μA
IBIAS (max)10 μA10 μA10 μA10 μA10 μA10 μA10 µA10 µA10 µA10 μA10 μA10 μA
IOUT65 mA65 mA65 mA65 mA65 mA65 mA65 mA65 mA65 mA65 mA65 mA65 mA
IS (per amp)5.6 mA5.6 mA5.6 mA5.6 mA5.6 mA5.6 mA5.6 mA5.6 mA5.6 mA5.6 mA5.6 mA5.6 mA
Noise VN12 nV/√Hz12 nV/√Hz12 nV/√Hz12 nV/√Hz12 nV/√Hz12 nV/√Hz12 nV/√Hz12 nV/√Hz12 nV/√Hz12 nV/√Hz12 nV/√Hz12 nV/√Hz
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Output Headroom0.1 V0.1 V0.1 V0.1 V0.1 V0.1 V0.1 V0.1 V0.1 V0.1 V0.1 V0.1 V
PSRR95 dB95 dB95 dB95 dB95 dB95 dB95 dB95 dB95 dB95 dB95 dB95 dB
Peak Temp240°C240°C240°C260°C260°C260°C240°C240°C240°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
Rail-to-Rail Input-Vs-Vs-Vs-Vs-Vs-Vs-Vs-Vs-Vs-Vs-Vs-Vs
Rail-to-Rail OutputYesYesYesYesYesYesYesYesYesYesYesYes
Скорость нарастания600 V/μs600 V/μs600 V/μs600 V/μs600 V/μs600 V/μs600 V/μs600 V/μs600 V/μs600 V/μs600 V/μs600 V/μs
Thermal ShutdownNoNoNoNoNoNoNoNoNoNoNoNo
TopologyVFAVFAVFAVFAVFAVFAVFAVFAVFAVFAVFAVFA
VOS (max)7 mV7 mV7 mV7 mV7 mV7 mV7 mV7 mV7 mV7 mV7 mV7 mV
VOUT4.85 V4.85 V4.85 V4.85 V4.85 V4.85 V4.85 V4.85 V4.85 V4.85 V4.85 V4.85 V
VS (max)5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VS (min)3 V3 V3 V3 V3 V3 V3 V3 V3 V3 V3 V3 V
RoHSСовместимСовместимСовместимСовместимСовместимСовместим
  • Amplifiers & Buffers > All Amplifiers > Amplifiers
На английском языке: Datasheet Intersil EL8302
