Клеммники KEEN SIDE
Datasheet Intersil EL5104 — Даташит
ПроизводительIntersil
СерияEL5104
Улучшенный VFA с поворотом 700 МГц
EL5104, EL5105, EL5204, EL5205, EL5304 Datasheet
PDF, 2.1 Мб, Версия: 2017-10-03
22 предложений от 22 поставщиков
Микросхема Буферный усилитель, OP Amp Single Volt Fdbk ‚±6.6V/13.2V 8Pin SOIC
EL5104IS
Intersil
65 ₽
EL5104IW-T7
Intersil
71 ₽
SUV System
EL5104IS
ТаймЧипс
EL5104IS
Intersil
EL5104ISEL5104IS-T13EL5104IS-T7EL5104ISZEL5104ISZ-T13EL5104ISZ-T7EL5104IW-T7EL5104IW-T7AEL5104IWZ-T7EL5104IWZ-T7A
N12345678910
Корпус8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R6 Ld SOT T+R6 Ld SOT T+R6 Ld SOT T+R6 Ld SOT T+R
Parameters / ModelsEL5104ISEL5104IS-T13EL5104IS-T7EL5104ISZEL5104ISZ-T13EL5104ISZ-T7EL5104IW-T7EL5104IW-T7AEL5104IWZ-T7EL5104IWZ-T7A
2nd Harmonic-80 dB-80 dB-80 dB-80 dB-80 dB-80 dB-80 dB-80 dB-80 dB-80 dB
3rd Harmonic-85 dB-85 dB-85 dB-85 dB-85 dB-85 dB-85 dB-85 dB-85 dB-85 dB
AVOL62 dB62 dB62 dB62 dB62 dB62 dB62 dB62 dB62 dB62 dB
Полоса частот700 MHz700 MHz700 MHz700 MHz700 MHz700 MHz700 MHz700 MHz700 MHz700 MHz
Количество каналов1111111111
Коэффициент подавления синфазного сигнала62 dB62 dB62 dB62 dB62 dB62 dB62 dB62 dB62 dB62 dB
Description700MHz Slew Enhanced VFA700MHz Slew Enhanced VFA700MHz Slew Enhanced VFA700MHz Slew Enhanced VFA700MHz Slew Enhanced VFA700MHz Slew Enhanced VFA700MHz Slew Enhanced VFA700MHz Slew Enhanced VFA700MHz Slew Enhanced VFA700MHz Slew Enhanced VFA
Diff Gain (%)0.010.010.010.010.010.010.010.010.010.01
Diff Phase (В°)0.020.020.020.020.020.020.020.020.020.02
Distortion Conditions2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz
EnableYesYesYesYesYesYesYesYesYesYes
Gain AV (min)1111111111
IBIAS8 µA8 µA8 µA8 μA8 μA8 μA8 µA8 µA8 μA8 μA
IBIAS (max)30 µA30 µA30 µA30 μA30 μA30 μA30 µA30 µA30 μA30 μA
IOUT160 mA160 mA160 mA160 mA160 mA160 mA160 mA160 mA160 mA160 mA
IS (per amp)9.5 mA9.5 mA9.5 mA9.5 mA9.5 mA9.5 mA9.5 mA9.5 mA9.5 mA9.5 mA
Noise VN10 nV/√Hz10 nV/√Hz10 nV/√Hz10 nV/√Hz10 nV/√Hz10 nV/√Hz10 nV/√Hz10 nV/√Hz10 nV/√Hz10 nV/√Hz
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Output Headroom1.2 V1.2 V1.2 V1.2 V1.2 V1.2 V1.2 V1.2 V1.2 V1.2 V
PSRR70 dB70 dB70 dB70 dB70 dB70 dB70 dB70 dB70 dB70 dB
Peak Temp240°C240°C240°C260°C260°C260°C240°C240°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
Rail-to-Rail InputNoNoNoNoNoNoNoNoNoNo
Rail-to-Rail OutputNoNoNoNoNoNoNoNoNoNo
Скорость нарастания7000 V/μs7000 V/μs7000 V/μs7000 V/μs7000 V/μs7000 V/μs7000 V/μs7000 V/μs7000 V/μs7000 V/μs
THD70 dB70 dB70 dB70 dB70 dB70 dB70 dB70 dB70 dB70 dB
Thermal ShutdownNoNoNoNoNoNoNoNoNoNo
TopologyVFAVFAVFAVFAVFAVFAVFAVFAVFAVFA
VOS (max)10 mV10 mV10 mV10 mV10 mV10 mV10 mV10 mV10 mV10 mV
VOUT7.6 V7.6 V7.6 V7.6 V7.6 V7.6 V7.6 V7.6 V7.6 V7.6 V
VS (max)10 V10 V10 V10 V10 V10 V10 V10 V10 V10 V
VS (min)5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V
RoHSСовместимСовместимСовместимСовместимСовместим
EL5105 EL5204 EL5205
  • Amplifiers & Buffers > All Amplifiers > Amplifiers
На английском языке: Datasheet Intersil EL5104
