Datasheet Intersil EL5306 — Даташит
ПроизводительIntersil
СерияEL5306
Усилители с фиксированным коэффициентом усиления 350 МГц и возможностью включения
EL5106, EL5306 Datasheet
PDF, 729 Кб, Версия: 2017-10-03
23 предложений от 23 поставщиков
EL5306IS
Intersil
26 ₽
727GS
EL5306IS
Intersil
116 ₽
Microfind
EL5306IUZ-T7
Renesas
735 ₽
ТаймЧипс
EL5306ISZ-T7
Intersil
EL5306ISEL5306IS-T13EL5306IS-T7EL5306ISZEL5306ISZ-T13EL5306ISZ-T7EL5306IUEL5306IU-T13EL5306IU-T7EL5306IUZEL5306IUZ-T13EL5306IUZ-T7
N123456789101112
Корпус16 Ld SOIC16 Ld SOIC T+R16 Ld SOIC T+R16 Ld SOIC16 Ld SOIC T+R16 Ld SOIC T+R16 Ld QSOP16 Ld QSOP T+R16 Ld QSOP T+R16 Ld QSOP16 Ld QSOP T+R16 Ld QSOP T+R
Parameters / ModelsEL5306ISEL5306IS-T13EL5306IS-T7EL5306ISZEL5306ISZ-T13EL5306ISZ-T7EL5306IUEL5306IU-T13EL5306IU-T7EL5306IUZEL5306IUZ-T13EL5306IUZ-T7
2nd Harmonic-70 dB-70 dB-70 dB-70 dB-70 dB-70 dB-70 dB-70 dB-70 dB-70 dB-70 dB-70 dB
3rd Harmonic-54 dB-54 dB-54 dB-54 dB-54 dB-54 dB-54 dB-54 dB-54 dB-54 dB-54 dB-54 dB
Полоса частот350 MHz350 MHz350 MHz350 MHz350 MHz350 MHz350 MHz350 MHz350 MHz350 MHz350 MHz350 MHz
Количество каналов333333333333
Description350MHz Fixed Gain Amplifiers with Enable350MHz Fixed Gain Amplifiers with Enable350MHz Fixed Gain Amplifiers with Enable350MHz Fixed Gain Amplifiers with Enable350MHz Fixed Gain Amplifiers with Enable350MHz Fixed Gain Amplifiers with Enable350MHz Fixed Gain Amplifiers with Enable350MHz Fixed Gain Amplifiers with Enable350MHz Fixed Gain Amplifiers with Enable350MHz Fixed Gain Amplifiers with Enable350MHz Fixed Gain Amplifiers with Enable350MHz Fixed Gain Amplifiers with Enable
Diff Gain (%)0.010.010.010.010.010.010.010.010.010.010.010.01
Diff Phase (В°)0.010.010.010.010.010.010.010.010.010.010.010.01
Distortion Conditions2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz2Vpp, 10MHz
EnableYesYesYesYesYesYesYesYesYesYesYesYes
Gain AV (min)111111111111
IBIAS1.5 μA1.5 μA1.5 μA1.5 μA1.5 μA1.5 μA1.5 μA1.5 μA1.5 μA1.5 μA1.5 μA1.5 μA
IBIAS (max)7 μA7 μA7 μA7 μA7 μA7 μA7 μA7 μA7 μA7 μA7 μA7 μA
IOUT100 mA100 mA100 mA100 mA100 mA100 mA100 mA100 mA100 mA100 mA100 mA100 mA
IS (per amp)1.5 mA1.5 mA1.5 mA1.5 mA1.5 mA1.5 mA1.5 mA1.5 mA1.5 mA1.5 mA1.5 mA1.5 mA
Noise VN2.8 nV/√Hz2.8 nV/√Hz2.8 nV/√Hz2.8 nV/√Hz2.8 nV/√Hz2.8 nV/√Hz2.8 nV/√Hz2.8 nV/√Hz2.8 nV/√Hz2.8 nV/√Hz2.8 nV/√Hz2.8 nV/√Hz
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Output Headroom1.15 V1.15 V1.15 V1.15 V1.15 V1.15 V1.15 V1.15 V1.15 V1.15 V1.15 V1.15 V
PSRR75 dB75 dB75 dB75 dB75 dB75 dB75 dB75 dB75 dB75 dB75 dB75 dB
Peak Temp240°C240°C240°C260°C260°C260°C240°C240°C240°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
Rail-to-Rail InputNoNoNoNoNoNoNoNoNoNoNoNo
Rail-to-Rail OutputNoNoNoNoNoNoNoNoNoNoNoNo
Скорость нарастания4500 V/μs4500 V/μs4500 V/μs4500 V/μs4500 V/μs4500 V/μs4500 V/μs4500 V/μs4500 V/μs4500 V/μs4500 V/μs4500 V/μs
Thermal ShutdownNoNoNoNoNoNoNoNoNoNoNoNo
TopologyFixed GainFixed GainFixed GainFixed GainFixed GainFixed GainFixed GainFixed GainFixed GainFixed GainFixed GainFixed Gain
VOS (max)10 mV10 mV10 mV10 mV10 mV10 mV10 mV10 mV10 mV10 mV10 mV10 mV
VOUT7.2 V7.2 V7.2 V7.2 V7.2 V7.2 V7.2 V7.2 V7.2 V7.2 V7.2 V7.2 V
VS (max)12 V12 V12 V12 V12 V12 V12 V12 V12 V12 V12 V12 V
VS (min)5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V
RoHSСовместимСовместимСовместимСовместимСовместимСовместим
EL5106
  • Amplifiers & Buffers > All Amplifiers > Amplifiers
На английском языке: Datasheet Intersil EL5306
