Datasheet Intersil EL5205 — Даташит
| Производитель | Intersil |
| Серия | EL5205 |
Улучшенный VFA с поворотом 700 МГц
EL5104, EL5105, EL5204, EL5205, EL5304 Datasheet
PDF, 2.1 Мб, Версия: 2017-10-03
Купить EL5205 на РадиоЛоцман.Цены — от 32 до 301 ₽21 предложений от 21 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные | |||
| EL5205IY Elantec | 32 ₽ | ||
| EL5205IS Intersil | 65 ₽ | ||
| EL5205ISZ-T7 Intersil | по запросу | ||
| EL5205ISZ-T13 Intersil | по запросу | ||
| EL5205IS | EL5205IS-T13 | EL5205IS-T7 | EL5205ISZ | EL5205ISZ-T13 | EL5205ISZ-T7 | EL5205IY | EL5205IY-T13 | EL5205IY-T7 | EL5205IYZ | EL5205IYZ-T13 | EL5205IYZ-T7 | |
| N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 |
| Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld MSOP | 8 Ld MSOP T+R | 8 Ld MSOP T+R | 8 Ld MSOP | 8 Ld MSOP T+R | 8 Ld MSOP T+R |
| Parameters / Models | EL5205IS | EL5205IS-T13 | EL5205IS-T7 | EL5205ISZ | EL5205ISZ-T13 | EL5205ISZ-T7 | EL5205IY | EL5205IY-T13 | EL5205IY-T7 | EL5205IYZ | EL5205IYZ-T13 | EL5205IYZ-T7 |
| 2nd Harmonic | -80 dB | -80 dB | -80 dB | -80 dB | -80 dB | -80 dB | -80 dB | -80 dB | -80 dB | -80 dB | -80 dB | -80 dB |
| 3rd Harmonic | -85 dB | -85 dB | -85 dB | -85 dB | -85 dB | -85 dB | -85 dB | -85 dB | -85 dB | -85 dB | -85 dB | -85 dB |
| AVOL | 62 dB | 62 dB | 62 dB | 62 dB | 62 dB | 62 dB | 62 dB | 62 dB | 62 dB | 62 dB | 62 dB | 62 dB |
| Полоса частот | 700 MHz | 700 MHz | 700 MHz | 700 MHz | 700 MHz | 700 MHz | 700 MHz | 700 MHz | 700 MHz | 700 MHz | 700 MHz | 700 MHz |
| Количество каналов | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
| Коэффициент подавления синфазного сигнала | 62 dB | 62 dB | 62 dB | 62 dB | 62 dB | 62 dB | 62 dB | 62 dB | 62 dB | 62 dB | 62 dB | 62 dB |
| Description | 700MHz Slew Enhanced VFA | 700MHz Slew Enhanced VFA | 700MHz Slew Enhanced VFA | 700MHz Slew Enhanced VFA | 700MHz Slew Enhanced VFA | 700MHz Slew Enhanced VFA | 700MHz Slew Enhanced VFA | 700MHz Slew Enhanced VFA | 700MHz Slew Enhanced VFA | 700MHz Slew Enhanced VFA | 700MHz Slew Enhanced VFA | 700MHz Slew Enhanced VFA |
| Diff Gain (%) | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 |
| Diff Phase (В°) | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 |
| Distortion Conditions | 2Vpp, 10MHz | 2Vpp, 10MHz | 2Vpp, 10MHz | 2Vpp, 10MHz | 2Vpp, 10MHz | 2Vpp, 10MHz | 2Vpp, 10MHz | 2Vpp, 10MHz | 2Vpp, 10MHz | 2Vpp, 10MHz | 2Vpp, 10MHz | 2Vpp, 10MHz |
| Enable | No | No | No | No | No | No | No | No | No | No | No | No |
| Gain AV (min) | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| IBIAS | 8 µA | 8 µA | 8 µA | 8 μA | 8 μA | 8 μA | 8 µA | 8 µA | 8 µA | 8 μA | 8 μA | 8 μA |
| IBIAS (max) | 30 µA | 30 µA | 30 µA | 30 μA | 30 μA | 30 μA | 30 µA | 30 µA | 30 µA | 30 μA | 30 μA | 30 μA |
| IOUT | 160 mA | 160 mA | 160 mA | 160 mA | 160 mA | 160 mA | 160 mA | 160 mA | 160 mA | 160 mA | 160 mA | 160 mA |
| IS (per amp) | 9.5 mA | 9.5 mA | 9.5 mA | 9.5 mA | 9.5 mA | 9.5 mA | 9.5 mA | 9.5 mA | 9.5 mA | 9.5 mA | 9.5 mA | 9.5 mA |
| Noise VN | 10 nV/√Hz | 10 nV/√Hz | 10 nV/√Hz | 10 nV/√Hz | 10 nV/√Hz | 10 nV/√Hz | 10 nV/√Hz | 10 nV/√Hz | 10 nV/√Hz | 10 nV/√Hz | 10 nV/√Hz | 10 nV/√Hz |
| Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Output Headroom | 1.2 V | 1.2 V | 1.2 V | 1.2 V | 1.2 V | 1.2 V | 1.2 V | 1.2 V | 1.2 V | 1.2 V | 1.2 V | 1.2 V |
| PSRR | 70 dB | 70 dB | 70 dB | 70 dB | 70 dB | 70 dB | 70 dB | 70 dB | 70 dB | 70 dB | 70 dB | 70 dB |
| Peak Temp | 240°C | 240°C | 240°C | 260°C | 260°C | 260°C | 240°C | 240°C | 240°C | 260°C | 260°C | 260°C |
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
| Rail-to-Rail Input | No | No | No | No | No | No | No | No | No | No | No | No |
| Rail-to-Rail Output | No | No | No | No | No | No | No | No | No | No | No | No |
| Скорость нарастания | 7000 V/μs | 7000 V/μs | 7000 V/μs | 7000 V/μs | 7000 V/μs | 7000 V/μs | 7000 V/μs | 7000 V/μs | 7000 V/μs | 7000 V/μs | 7000 V/μs | 7000 V/μs |
| THD | 70 dB | 70 dB | 70 dB | 70 dB | 70 dB | 70 dB | 70 dB | 70 dB | 70 dB | 70 dB | 70 dB | 70 dB |
| Thermal Shutdown | No | No | No | No | No | No | No | No | No | No | No | No |
| Topology | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA |
| VOS (max) | 10 mV | 10 mV | 10 mV | 10 mV | 10 mV | 10 mV | 10 mV | 10 mV | 10 mV | 10 mV | 10 mV | 10 mV |
| VOUT | 7.6 V | 7.6 V | 7.6 V | 7.6 V | 7.6 V | 7.6 V | 7.6 V | 7.6 V | 7.6 V | 7.6 V | 7.6 V | 7.6 V |
| VS (max) | 10 V | 10 V | 10 V | 10 V | 10 V | 10 V | 10 V | 10 V | 10 V | 10 V | 10 V | 10 V |
| VS (min) | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V |
| RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: EL5205 (12)
- Amplifiers & Buffers > All Amplifiers > Amplifiers
