Datasheet Intersil EL5375 — Даташит
| Производитель | Intersil |
| Серия | EL5375 |
Приемники дифференциальной линии 550 МГц
Купить EL5375 на РадиоЛоцман.Цены — от 65 до 1 037 ₽51 предложений от 25 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные | |||
| EL5375IUZ-T13 Renesas | 121 ₽ | ||
| EL5375IUZ Intersil | по запросу | ||
| EL5375IUZ-T7 Elantec | по запросу | ||
| EL5375IU-T13 Intersil | по запросу | ||
| EL5375IU | EL5375IU-T13 | EL5375IU-T7 | EL5375IUZ | EL5375IUZ-T13 | EL5375IUZ-T7 | |
| N | 1 | 2 | 3 | 4 | 5 | 6 |
| Корпус | 24 Ld QSOP | 24 Ld QSOP T+R | 24 Ld QSOP T+R | 24 Ld QSOP | 24 Ld QSOP T+R | 24 Ld QSOP T+R |
| Parameters / Models | EL5375IU | EL5375IU-T13 | EL5375IU-T7 | EL5375IUZ | EL5375IUZ-T13 | EL5375IUZ-T7 |
| 2nd Harmonic | -65 dB | -65 dB | -65 dB | -65 dB | -65 dB | -65 dB |
| 3rd Harmonic | -78 dB | -78 dB | -78 dB | -78 dB | -78 dB | -78 dB |
| Полоса частот | 550 MHz | 550 MHz | 550 MHz | 550 MHz | 550 MHz | 550 MHz |
| Количество каналов | 3 | 3 | 3 | 3 | 3 | 3 |
| Коэффициент подавления синфазного сигнала | 95 dB | 95 dB | 95 dB | 95 dB | 95 dB | 95 dB |
| Description | 550MHz Differential Line Receivers | 550MHz Differential Line Receivers | 550MHz Differential Line Receivers | 550MHz Differential Line Receivers | 550MHz Differential Line Receivers | 550MHz Differential Line Receivers |
| Diff Gain (%) | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 |
| Diff Phase (В°) | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 |
| Distortion Conditions | 2Vpp, 5MHz | 2Vpp, 5MHz | 2Vpp, 5MHz | 2Vpp, 5MHz | 2Vpp, 5MHz | 2Vpp, 5MHz |
| Enable | Yes | Yes | Yes | Yes | Yes | Yes |
| Gain AV (min) | 1 | 1 | 1 | 1 | 1 | 1 |
| IBIAS | 12.5 µA | 12.5 µA | 12.5 µA | 12.5 μA | 12.5 μA | 12.5 μA |
| IBIAS (max) | 25 µA | 25 µA | 25 µA | 25 μA | 25 μA | 25 μA |
| IOUT | 67 mA | 67 mA | 67 mA | 67 mA | 67 mA | 67 mA |
| IS (per amp) | 9.6 mA | 9.6 mA | 9.6 mA | 9.6 mA | 9.6 mA | 9.6 mA |
| Noise VN | 21 nV/√Hz | 21 nV/√Hz | 21 nV/√Hz | 21 nV/√Hz | 21 nV/√Hz | 21 nV/√Hz |
| Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Output Headroom | 1.46 V | 1.46 V | 1.46 V | 1.46 V | 1.46 V | 1.46 V |
| PSRR | 56 dB | 56 dB | 56 dB | 56 dB | 56 dB | 56 dB |
| Peak Temp | 240°C | 240°C | 240°C | 260°C | 260°C | 260°C |
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard |
| Rail-to-Rail Input | No | No | No | No | No | No |
| Rail-to-Rail Output | No | No | No | No | No | No |
| Скорость нарастания | 900 V/μs | 900 V/μs | 900 V/μs | 900 V/μs | 900 V/μs | 900 V/μs |
| Thermal Shutdown | No | No | No | No | No | No |
| Topology | VFA | VFA | VFA | VFA | VFA | VFA |
| VOS (max) | 30 mV | 30 mV | 30 mV | 30 mV | 30 mV | 30 mV |
| VOUT | 7.49 V | 7.49 V | 7.49 V | 7.49 V | 7.49 V | 7.49 V |
| VS (max) | 11 V | 11 V | 11 V | 11 V | 11 V | 11 V |
| VS (min) | 4.75 V | 4.75 V | 4.75 V | 4.75 V | 4.75 V | 4.75 V |
| RoHS | Совместим | Совместим | Совместим |
Серия: EL5375 (6)
- Amplifiers & Buffers > All Amplifiers > Amplifiers
