Datasheet Intersil EL5175 — Даташит
Производитель | Intersil |
Серия | EL5175 |
Приемники дифференциальной линии 550 МГц
![]() 30 предложений от 22 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные | |||
EL5175ISZ Renesas | 314 ₽ | ||
EL5175IS-T7 Intersil | по запросу | ||
EL5175IS-T13 Intersil | по запросу | ||
EL5175ISZ-T13 Intersil | по запросу |
EL5175IS | EL5175IS-T13 | EL5175IS-T7 | EL5175ISZ | EL5175ISZ-T13 | EL5175ISZ-T7 | EL5175IY | EL5175IY-T13 | EL5175IY-T7 | EL5175IYZ | EL5175IYZ-T13 | EL5175IYZ-T7 | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 |
Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld MSOP | 8 Ld MSOP T+R | 8 Ld MSOP T+R | 8 Ld MSOP | 8 Ld MSOP T+R | 8 Ld MSOP T+R |
Parameters / Models | EL5175IS | EL5175IS-T13 | EL5175IS-T7 | EL5175ISZ | EL5175ISZ-T13 | EL5175ISZ-T7 | EL5175IY | EL5175IY-T13 | EL5175IY-T7 | EL5175IYZ | EL5175IYZ-T13 | EL5175IYZ-T7 |
2nd Harmonic | -65 dB | -65 dB | -65 dB | -65 dB | -65 dB | -65 dB | -65 dB | -65 dB | -65 dB | -65 dB | -65 dB | -65 dB |
3rd Harmonic | -78 dB | -78 dB | -78 dB | -78 dB | -78 dB | -78 dB | -78 dB | -78 dB | -78 dB | -78 dB | -78 dB | -78 dB |
Полоса частот | 550 MHz | 550 MHz | 550 MHz | 550 MHz | 550 MHz | 550 MHz | 550 MHz | 550 MHz | 550 MHz | 550 MHz | 550 MHz | 550 MHz |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Коэффициент подавления синфазного сигнала | 95 dB | 95 dB | 95 dB | 95 dB | 95 dB | 95 dB | 95 dB | 95 dB | 95 dB | 95 dB | 95 dB | 95 dB |
Description | 550MHz Differential Line Receivers | 550MHz Differential Line Receivers | 550MHz Differential Line Receivers | 550MHz Differential Line Receivers | 550MHz Differential Line Receivers | 550MHz Differential Line Receivers | 550MHz Differential Line Receivers | 550MHz Differential Line Receivers | 550MHz Differential Line Receivers | 550MHz Differential Line Receivers | 550MHz Differential Line Receivers | 550MHz Differential Line Receivers |
Diff Gain (%) | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 |
Diff Phase (В°) | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 |
Distortion Conditions | 2Vpp, 5MHz | 2Vpp, 5MHz | 2Vpp, 5MHz | 2Vpp, 5MHz | 2Vpp, 5MHz | 2Vpp, 5MHz | 2Vpp, 5MHz | 2Vpp, 5MHz | 2Vpp, 5MHz | 2Vpp, 5MHz | 2Vpp, 5MHz | 2Vpp, 5MHz |
Enable | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Gain AV (min) | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
IBIAS | 12.5 µA | 12.5 µA | 12.5 µA | 12.5 μA | 12.5 μA | 12.5 μA | 12.5 µA | 12.5 µA | 12.5 µA | 12.5 μA | 12.5 μA | 12.5 μA |
IBIAS (max) | 25 µA | 25 µA | 25 µA | 25 μA | 25 μA | 25 μA | 25 µA | 25 µA | 25 µA | 25 μA | 25 μA | 25 μA |
IOUT | 67 mA | 67 mA | 67 mA | 67 mA | 67 mA | 67 mA | 67 mA | 67 mA | 67 mA | 67 mA | 67 mA | 67 mA |
IS (per amp) | 9.6 mA | 9.6 mA | 9.6 mA | 9.6 mA | 9.6 mA | 9.6 mA | 9.6 mA | 9.6 mA | 9.6 mA | 9.6 mA | 9.6 mA | 9.6 mA |
Noise VN | 21 nV/√Hz | 21 nV/√Hz | 21 nV/√Hz | 21 nV/√Hz | 21 nV/√Hz | 21 nV/√Hz | 21 nV/√Hz | 21 nV/√Hz | 21 nV/√Hz | 21 nV/√Hz | 21 nV/√Hz | 21 nV/√Hz |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Output Headroom | 1.46 V | 1.46 V | 1.46 V | 1.46 V | 1.46 V | 1.46 V | 1.46 V | 1.46 V | 1.46 V | 1.46 V | 1.46 V | 1.46 V |
PSRR | 56 dB | 56 dB | 56 dB | 56 dB | 56 dB | 56 dB | 56 dB | 56 dB | 56 dB | 56 dB | 56 dB | 56 dB |
Peak Temp | 240°C | 240°C | 240°C | 260°C | 260°C | 260°C | 240°C | 240°C | 240°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
Rail-to-Rail Input | No | No | No | No | No | No | No | No | No | No | No | No |
Rail-to-Rail Output | No | No | No | No | No | No | No | No | No | No | No | No |
Скорость нарастания | 600 V/μs | 600 V/μs | 600 V/μs | 600 V/μs | 600 V/μs | 600 V/μs | 600 V/μs | 600 V/μs | 600 V/μs | 600 V/μs | 600 V/μs | 600 V/μs |
Thermal Shutdown | No | No | No | No | No | No | No | No | No | No | No | No |
Topology | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA | VFA |
VOS (max) | 40 mV | 40 mV | 40 mV | 40 mV | 40 mV | 40 mV | 40 mV | 40 mV | 40 mV | 40 mV | 40 mV | 40 mV |
VOUT | 7.49 V | 7.49 V | 7.49 V | 7.49 V | 7.49 V | 7.49 V | 7.49 V | 7.49 V | 7.49 V | 7.49 V | 7.49 V | 7.49 V |
VS (max) | 11 V | 11 V | 11 V | 11 V | 11 V | 11 V | 11 V | 11 V | 11 V | 11 V | 11 V | 11 V |
VS (min) | 4.75 V | 4.75 V | 4.75 V | 4.75 V | 4.75 V | 4.75 V | 4.75 V | 4.75 V | 4.75 V | 4.75 V | 4.75 V | 4.75 V |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: EL5175 (12)
- Amplifiers & Buffers > All Amplifiers > Amplifiers
