Datasheet Intersil EL5420 — Даташит
ПроизводительIntersil
СерияEL5420
Операционные усилители ввода-вывода 12 МГц с Rail-to-Rail
EL5120, EL5220, EL5420 Datasheet
PDF, 955 Кб, Версия: 03-10-2017
37 предложений от 26 поставщиков
EL5420TIRZ
Renesas
45 ₽
EL5420CS-T13
Intersil
65 ₽
EL5420CS
90 ₽
Десси
Транзистор биполярный EL5420CRZ
Intersil
297 ₽
EL5420CLEL5420CL-T13EL5420CL-T7EL5420CLZEL5420CLZ-T13EL5420CLZ-T7EL5420CREL5420CR-T13EL5420CR-T7EL5420CRZEL5420CRZ-T13EL5420CRZ-T7EL5420CRZ-T7AEL5420CSEL5420CS-T13EL5420CS-T7EL5420CSZEL5420CSZ-T13EL5420CSZ-T7
N12345678910111213141516171819
Корпус24 Ld QFN24 Ld QFN T+R24 Ld QFN T+R16 Ld QFN16 Ld QFN T+R16 Ld QFN T+R14 Ld TSSOP14 Ld TSSOP T+R14 Ld TSSOP T+R14 Ld TSSOP14 Ld TSSOP T+R14 Ld TSSOP T+R14 Ld TSSOP T+R14 Ld SOIC14 Ld SOIC T+R14 Ld SOIC T+R14 Ld SOIC14 Ld SOIC T+R14 Ld SOIC T+R
Parameters / ModelsEL5420CLEL5420CL-T13EL5420CL-T7EL5420CLZEL5420CLZ-T13EL5420CLZ-T7EL5420CREL5420CR-T13EL5420CR-T7EL5420CRZEL5420CRZ-T13EL5420CRZ-T7EL5420CRZ-T7AEL5420CSEL5420CS-T13EL5420CS-T7EL5420CSZEL5420CSZ-T13EL5420CSZ-T7
Полоса частот12 MHz12 MHz12 MHz12 MHz12 MHz12 MHz12 MHz12 MHz12 MHz12 MHz12 MHz12 MHz12 MHz12 MHz12 MHz12 MHz12 MHz12 MHz12 MHz
Количество каналов4444444444444444444
Description12MHz Rail-to-Rail Input-Output Op Amps12MHz Rail-to-Rail Input-Output Op Amps12MHz Rail-to-Rail Input-Output Op Amps12MHz Rail-to-Rail Input-Output Op Amps12MHz Rail-to-Rail Input-Output Op Amps12MHz Rail-to-Rail Input-Output Op Amps12MHz Rail-to-Rail Input-Output Op Amps12MHz Rail-to-Rail Input-Output Op Amps12MHz Rail-to-Rail Input-Output Op Amps12MHz Rail-to-Rail Input-Output Op Amps12MHz Rail-to-Rail Input-Output Op Amps12MHz Rail-to-Rail Input-Output Op Amps12MHz Rail-to-Rail Input-Output Op Amps12MHz Rail-to-Rail Input-Output Op Amps12MHz Rail-to-Rail Input-Output Op Amps12MHz Rail-to-Rail Input-Output Op Amps12MHz Rail-to-Rail Input-Output Op Amps12MHz Rail-to-Rail Input-Output Op Amps12MHz Rail-to-Rail Input-Output Op Amps
IOUT30 mA30 mA30 mA30 mA30 mA30 mA30 mA30 mA30 mA30 mA30 mA30 mA30 mA30 mA30 mA30 mA30 mA30 mA30 mA
IS0.5 mA0.5 mA0.5 mA0.5 mA0.5 mA0.5 mA0.5 mA0.5 mA0.5 mA0.5 mA0.5 mA0.5 mA0.5 mA0.5 mA0.5 mA0.5 mA0.5 mA0.5 mA0.5 mA
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp240°C240°C240°C260°C260°C260°C240°C240°C240°C260°C260°C260°C260°C240°C240°C240°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
Rail-to-Rail InputYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes
Rail-to-Rail OutputYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes
Скорость нарастания10 V/μs10 V/μs10 V/μs10 V/μs10 V/μs10 V/μs10 V/μs10 V/μs10 V/μs10 V/μs10 V/μs10 V/μs10 V/μs10 V/μs10 V/μs10 V/μs10 V/μs10 V/μs10 V/μs
VS (max)16.5 V16.5 V16.5 V16.5 V16.5 V16.5 V16.5 V16.5 V16.5 V16.5 V16.5 V16.5 V16.5 V16.5 V16.5 V16.5 V16.5 V16.5 V16.5 V
VS (min)4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
EL5220
  • Amplifiers & Buffers > Display Amplifiers and Buffers > Vcom Amplifiers
На английском языке: Datasheet Intersil EL5420
