Datasheet Intersil HFA1112 — Даташит
Производитель | Intersil |
Серия | HFA1112 |
850 МГц, буферный усилитель с программируемым усилением и малыми искажениями
![]() 26 предложений от 23 поставщиков Микросхема Операционный усилитель, Pb-Free w/Anneal BUFFER 850MHz CFB PRG-GAIN 8SOIC IND HT SUSA CODE:8542330000 | |||
HFA1112IJ Rochester Electronics | от 36 ₽ | ||
HFA1112-S Intersil | по запросу | ||
HFA1112IJ | по запросу | ||
HFA1112IBZ96 Intersil | по запросу |
HFA1112AIB96 | HFA1112AIP | HFA1112IB | HFA1112IB96 | HFA1112IBZ | HFA1112IBZ96 | HFA1112IP | HFA1112IPZ | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
Корпус | 8 Ld SOIC T+R | 8 Ld PDIP | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld PDIP | 8 Ld PDIP |
Parameters / Models | HFA1112AIB96 | HFA1112AIP | HFA1112IB | HFA1112IB96 | HFA1112IBZ | HFA1112IBZ96 | HFA1112IP | HFA1112IPZ |
2nd Harmonic | -57 dB | -57 dB | -57 dB | -57 dB | -57 dB | -57 dB | -57 dB | -57 dB |
3rd Harmonic | -73 dB | -73 dB | -73 dB | -73 dB | -73 dB | -73 dB | -73 dB | -73 dB |
Полоса частот | 850 MHz | 850 MHz | 850 MHz | 850 MHz | 850 MHz | 850 MHz | 850 MHz | 850 MHz |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Description | 850MHz, Low Distortion Programmable Gain Buffer Amplifier | 850MHz, Low Distortion Programmable Gain Buffer Amplifier | 850MHz, Low Distortion Programmable Gain Buffer Amplifier | 850MHz, Low Distortion Programmable Gain Buffer Amplifier | 850MHz, Low Distortion Programmable Gain Buffer Amplifier | 850MHz, Low Distortion Programmable Gain Buffer Amplifier | 850MHz, Low Distortion Programmable Gain Buffer Amplifier | 850MHz, Low Distortion Programmable Gain Buffer Amplifier |
Diff Gain (%) | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 |
Diff Phase (В°) | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 |
Distortion Conditions | 2Vpp, 30MHz | 2Vpp, 30MHz | 2Vpp, 30MHz | 2Vpp, 30MHz | 2Vpp, 30MHz | 2Vpp, 30MHz | 2Vpp, 30MHz | 2Vpp, 30MHz |
Enable | No | No | No | No | No | No | No | No |
Gain AV (min) | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
IBIAS | 25 μA | 25 μA | 25 μA | 25 μA | 25 μA | 25 μA | 25 μA | 25 μA |
IBIAS (max) | 40 μA | 40 μA | 40 μA | 40 μA | 40 μA | 40 μA | 40 μA | 40 μA |
IOUT | 60 mA | 60 mA | 60 mA | 60 mA | 60 mA | 60 mA | 60 mA | 60 mA |
IS (per amp) | 21 mA | 21 mA | 21 mA | 21 mA | 21 mA | 21 mA | 21 mA | 21 mA |
Noise VN | 9 nV/√Hz | 9 nV/√Hz | 9 nV/√Hz | 9 nV/√Hz | 9 nV/√Hz | 9 nV/√Hz | 9 nV/√Hz | 9 nV/√Hz |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Output Headroom | 1.7 V | 1.7 V | 1.7 V | 1.7 V | 1.7 V | 1.7 V | 1.7 V | 1.7 V |
PSRR | 45 dB | 45 dB | 45 dB | 45 dB | 45 dB | 45 dB | 45 dB | 45 dB |
Peak Temp | 240°C | 240°C | 240°C | 260°C | 260°C | |||
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
Rail-to-Rail Input | No | No | No | No | No | No | No | No |
Rail-to-Rail Output | No | No | No | No | No | No | No | No |
Скорость нарастания | 2400 V/μs | 2400 V/μs | 2400 V/μs | 2400 V/μs | 2400 V/μs | 2400 V/μs | 2400 V/μs | 2400 V/μs |
Thermal Shutdown | No | No | No | No | No | No | No | No |
Topology | Fixed Gain | Fixed Gain | Fixed Gain | Fixed Gain | Fixed Gain | Fixed Gain | Fixed Gain | Fixed Gain |
VOS (max) | 25 mV | 25 mV | 25 mV | 25 mV | 25 mV | 25 mV | 25 mV | 25 mV |
VOUT | 6.6 V | 6.6 V | 6.6 V | 6.6 V | 6.6 V | 6.6 V | 6.6 V | 6.6 V |
VS (max) | 11 V | 11 V | 11 V | 11 V | 11 V | 11 V | 11 V | 11 V |
VS (min) | 9 V | 9 V | 9 V | 9 V | 9 V | 9 V | 9 V | 9 V |
Серия: HFA1112 (8)
- Amplifiers & Buffers > All Amplifiers > Amplifiers
