Datasheet Intersil ISL54064 — Даташит
ПроизводительIntersil
СерияISL54064
Отрицательное колебание сигнала, субомное сопротивление, двойное SPST с одним переключателем питания с устранением щелчков и хлопков
ISL54063, ISL54064 Datasheet
PDF, 764 Кб, Версия: 2017-10-11
, Negative Signal Swing, Sub-ohm, Dual SPST with Click and Pop Elimination Single Supply Switch
ISL54064IRTZ
Renesas
26 ₽
ISL54064IRTZ
Renesas
81 ₽
ISL54064IRTZ
Intersil
LifeElectronics
ISL54064IRUZ-T
Intersil
ISL54064IRTZISL54064IRTZ-TISL54064IRUZ-T
N123
Корпус10 Ld DFN10 Ld DFN T+R10 Ld uTQFN T+R
Parameters / ModelsISL54064IRTZISL54064IRTZ-TISL54064IRUZ-T
ConfigurationDual NCDual NCDual NC
DescriptionNegative Signal Swing, Sub-ohm, Dual SPST with Click and Pop Elimination Single Supply SwitchNegative Signal Swing, Sub-ohm, Dual SPST with Click and Pop Elimination Single Supply SwitchNegative Signal Swing, Sub-ohm, Dual SPST with Click and Pop Elimination Single Supply Switch
Insertion Loss @ 20kΩ LoadN/A dBN/A dBN/A dB
Insertion Loss @ 20kО© LoadN/A dBN/A dBN/A dB
Off-Isolation @ 20kHz, 20kΩ LoadN/A dBN/A dBN/A dB
Off-Isolation @ 20kHz, 20kО© LoadN/A dBN/A dBN/A dB
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85
Peak Temp260°C260°C260°C
Qualification LevelStandardStandardStandard
Switch or MUXStereo SwitchStereo SwitchStereo Switch
THD+N 20kΩ Load @ 2VRMS (%)0.040.040.04
THD+N 20kО© Load @ 2VRMS (%)0.040.040.04
THD+N 32Ω Load @ 3.9mW (%)0.020.020.02
THD+N 32О© Load @ 3.9mW (%)0.020.020.02
Type of SwitchSPSTSPSTSPST
VS (max)6.5 V6.5 V6.5 V
VS (min)1.8 V1.8 V1.8 V
rDS(ON)0.65 Ω0.65 Ω0.65 Ω
ISL54063
  • Audio & Video > Audio Switches > Audio Click and Pop
На английском языке: Datasheet Intersil ISL54064
