Datasheet Intersil ISL54063 — Даташит
| Производитель | Intersil |
| Серия | ISL54063 |
Отрицательное колебание сигнала, субомное сопротивление, двойное SPST с одним переключателем питания с устранением щелчков и хлопков
Купить ISL54063 на РадиоЛоцман.Цены — от 25 до 80 ₽13 предложений от 13 поставщиков , Negative Signal Swing, Sub-ohm, Dual SPST with Click and Pop Elimination Single Supply Switch | |||
| ISL54063IRTZ Renesas | 25 ₽ | ||
| ISL54063IRTZ Intersil | 65 ₽ | ||
| ISL54063IRTZ Renesas | 80 ₽ | ||
| ISL54063IRTZ Intersil | по запросу | ||
| ISL54063IRTZ | ISL54063IRTZ-T | ISL54063IRUZ-T | |
| N | 1 | 2 | 3 |
| Корпус | 10 Ld DFN | 10 Ld DFN T+R | 10 Ld uTQFN T+R |
| Parameters / Models | ISL54063IRTZ | ISL54063IRTZ-T | ISL54063IRUZ-T |
| Configuration | Dual NO | Dual NO | Dual NO |
| Description | Negative Signal Swing, Sub-ohm, Dual SPST with Click and Pop Elimination Single Supply Switch | Negative Signal Swing, Sub-ohm, Dual SPST with Click and Pop Elimination Single Supply Switch | Negative Signal Swing, Sub-ohm, Dual SPST with Click and Pop Elimination Single Supply Switch |
| Insertion Loss @ 20kΩ Load | N/A dB | N/A dB | N/A dB |
| Insertion Loss @ 20kО© Load | N/A dB | N/A dB | N/A dB |
| Off-Isolation @ 20kHz, 20kΩ Load | N/A dB | N/A dB | N/A dB |
| Off-Isolation @ 20kHz, 20kО© Load | N/A dB | N/A dB | N/A dB |
| Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Peak Temp | 260°C | 260°C | 260°C |
| Qualification Level | Standard | Standard | Standard |
| Switch or MUX | Stereo Switch | Stereo Switch | Stereo Switch |
| THD+N 20kΩ Load @ 2VRMS (%) | 0.04 | 0.04 | 0.04 |
| THD+N 20kО© Load @ 2VRMS (%) | 0.04 | 0.04 | 0.04 |
| THD+N 32Ω Load @ 3.9mW (%) | 0.02 | 0.02 | 0.02 |
| THD+N 32О© Load @ 3.9mW (%) | 0.02 | 0.02 | 0.02 |
| Type of Switch | SPST | SPST | SPST |
| VS (max) | 6.5 V | 6.5 V | 6.5 V |
| VS (min) | 1.8 V | 1.8 V | 1.8 V |
| rDS(ON) | 0.65 Ω | 0.65 Ω | 0.65 Ω |
| RoHS | Совместим | Совместим | Совместим |
Серия: ISL54063 (3)
- Audio & Video > Audio Switches > Audio Click and Pop
