Datasheet Intersil ISL54062 — Даташит
| Производитель | Intersil |
| Серия | ISL54062 |
Отрицательное колебание сигнала, субомное сопротивление, двойной однополюсный контакт с функцией устранения щелчков и толчков, одиночный переключатель питания
Купить ISL54062 на РадиоЛоцман.Цены — от 26 до 90 ₽14 предложений от 14 поставщиков , Negative Signal Swing, Sub-ohm, Dual SPDT with Click and Pop Elimination Single Supply Switch | |||
| ISL54062IRTZ-T Renesas | 26 ₽ | ||
| ISL54062IRTZ Renesas | 27 ₽ | ||
| ISL54062IRTZ-T Intersil | 66 ₽ | ||
| ISL54062IRTZ Renesas | 81 ₽ | ||
| ISL54062IRTZ | ISL54062IRTZ-T | ISL54062IRUZ-T | |
| N | 1 | 2 | 3 |
| Корпус | 10 Ld DFN | 10 Ld DFN T+R | 10 Ld uTQFN T+R |
| Parameters / Models | ISL54062IRTZ | ISL54062IRTZ-T | ISL54062IRUZ-T |
| Configuration | Dual NO | Dual NO | Dual NO |
| Description | Negative Signal Swing, Sub-ohm, Dual SPDT with Click and Pop Elimination Single Supply Switch | Negative Signal Swing, Sub-ohm, Dual SPDT with Click and Pop Elimination Single Supply Switch | Negative Signal Swing, Sub-ohm, Dual SPDT with Click and Pop Elimination Single Supply Switch |
| Insertion Loss @ 20kΩ Load | N/A dB | N/A dB | N/A dB |
| Insertion Loss @ 20kО© Load | N/A dB | N/A dB | N/A dB |
| Off-Isolation @ 20kHz, 20kΩ Load | N/A dB | N/A dB | N/A dB |
| Off-Isolation @ 20kHz, 20kО© Load | N/A dB | N/A dB | N/A dB |
| Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Peak Temp | 260°C | 260°C | 260°C |
| Qualification Level | Standard | Standard | Standard |
| Switch or MUX | Stereo Switch | Stereo Switch | Stereo Switch |
| THD+N 20kΩ Load @ 2VRMS (%) | 0.04 | 0.04 | 0.04 |
| THD+N 20kО© Load @ 2VRMS (%) | 0.04 | 0.04 | 0.04 |
| THD+N 32Ω Load @ 3.9mW (%) | 0.02 | 0.02 | 0.02 |
| THD+N 32О© Load @ 3.9mW (%) | 0.02 | 0.02 | 0.02 |
| Type of Switch | SPDT | SPDT | SPDT |
| VS (max) | 6.5 V | 6.5 V | 6.5 V |
| VS (min) | 1.8 V | 1.8 V | 1.8 V |
| rDS(ON) | 0.57 Ω | 0.57 Ω | 0.57 Ω |
| RoHS | Совместим | Совместим | Совместим |
Серия: ISL54062 (3)
- Audio & Video > Audio Switches > Audio Click and Pop
