Datasheet Intersil ISL97691 — Даташит
Производитель | Intersil |
Серия | ISL97691 |
Светодиодный драйвер 2,4 В с независимым аналоговым и ШИМ-регулированием яркости двух ламп подсветки для 3D-приложений
![]() 13 предложений от 13 поставщиков LED привод, LED DRVR 2.5V/3.3V/5V 16Pin TQFN EP T/R | |||
ISL97691IRTZ-TK Renesas | по запросу | ||
ISL97691IRTZ-T | по запросу | ||
ISL97691IRTZ Intersil | по запросу | ||
ISL97691IRTZ | ISL97691IRTZ-T | ISL97691IRTZ-TK | |
N | 1 | 2 | 3 |
Корпус | 16 Ld TQFN | 16 Ld TQFN T+R | 16 Ld TQFN T+R |
Parameters / Models | ISL97691IRTZ | ISL97691IRTZ-T | ISL97691IRTZ-TK |
# of LEDs (max) | 4-channel 21V 60mA LED Driver | 4-channel 21V 60mA LED Driver | 4-channel 21V 60mA LED Driver |
Backlight for LCD Size (max) | 17 in | 17 in | 17 in |
Backlight for LCD Size (min) | 0 in | 0 in | 0 in |
Brightness Control | Yes | Yes | Yes |
Количество каналов | 4 | 4 | 4 |
Description | 2.4V LED Driver with Independent Analog and PWM Dimming Controls of 2 Backlights for 3D Application | 2.4V LED Driver with Independent Analog and PWM Dimming Controls of 2 Backlights for 3D Application | 2.4V LED Driver with Independent Analog and PWM Dimming Controls of 2 Backlights for 3D Application |
Fault Switch | Yes | Yes | Yes |
Тактовая частота | 400kHz to 1.5 MHz | 400kHz to 1.5 MHz | 400kHz to 1.5 MHz |
IQ (max) | 1 mA | 1 mA | 1 mA |
ISW (typ) | 2800 mA | 2800 mA | 2800 mA |
Integrated Diode | No | No | No |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Output Current Max/Channel | 60 mA | 60 mA | 60 mA |
Over Voltage Protection | Yes | Yes | Yes |
Peak Efficiency (%) | 90 | 90 | 90 |
Peak Temp | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard |
Topologies | Inductor Boost | Inductor Boost | Inductor Boost |
Total Current for DC/DC Lighting | 240 mA | 240 mA | 240 mA |
VIN (max) (V) | 5.5 | 5.5 | 5.5 |
VIN (min) (V) | 2.4 | 2.4 | 2.4 |
VOUT (max) (V) | 21 | 21 | 21 |
Серия: ISL97691 (3)
- Audio & Video > Display ICs > LED Backlight Drivers
