Datasheet Intersil ISL97673 — Даташит
Производитель | Intersil |
Серия | ISL97673 |
6-канальный светодиодный драйвер с SMBus или ШИМ-регулированием яркости и управлением фазовым сдвигом
![]() 15 предложений от 15 поставщиков , LED Driver 78Segment 5V/9V/12V/15V/18V/24V Automotive 20Pin QFN EP Tube | |||
ISL97673IRZ-T Intersil | по запросу | ||
ISL97673IRZ-EVAL Intersil | по запросу | ||
ISL97673IRZ Renesas | по запросу | ||
ISL97673IRZ-TK Intersil | по запросу |
ISL97673IRZ | ISL97673IRZ-T | ISL97673IRZ-TK | |
N | 1 | 2 | 3 |
Корпус | 20 Ld QFN | 20 Ld QFN T+R | 20 Ld QFN T+R |
Parameters / Models | ISL97673IRZ | ISL97673IRZ-T | ISL97673IRZ-TK |
# of LEDs (max) | 78 | 78 | 78 |
Backlight for LCD Size (max) | 17 in | 17 in | 17 in |
Backlight for LCD Size (min) | 0 in | 0 in | 0 in |
Brightness Control | SMBus, PWM or DC | SMBus, PWM or DC | SMBus, PWM or DC |
Количество каналов | 6 | 6 | 6 |
Description | 6-Channel SMBus or PWM Dimming LED Driver with Phase Shift Control | 6-Channel SMBus or PWM Dimming LED Driver with Phase Shift Control | 6-Channel SMBus or PWM Dimming LED Driver with Phase Shift Control |
Fault Switch | Yes | Yes | Yes |
Тактовая частота | 0.6/1.2 MHz | 0.6/1.2 MHz | 0.6/1.2 MHz |
IQ (max) | 5 μA | 5 μA | 5 μA |
IS (max) | 5 mA | 5 mA | 5 mA |
ISW (typ) | 2000 mA | 2000 mA | 2000 mA |
Integrated Diode | No | No | No |
Interface Type | SMBus/I2C | SMBus/I2C | SMBus/I2C |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Output Current Max/Channel | 40 mA | 40 mA | 40 mA |
Over Voltage Protection | Yes | Yes | Yes |
Peak Efficiency (%) | 92.9 | 92.9 | 92.9 |
Peak Temp | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard |
Topologies | Inductor Boost | Inductor Boost | Inductor Boost |
Total Current for DC/DC Lighting | 240 mA | 240 mA | 240 mA |
VIN (max) (V) | 26.5 | 26.5 | 26.5 |
VIN (min) (V) | 4.5 | 4.5 | 4.5 |
VOUT (max) (V) | 45 | 45 | 45 |
Интерфейс | SMBus/I2C | SMBus/I2C | SMBus/I2C |
Серия: ISL97673 (3)
- Audio & Video > Display ICs > LED Backlight Drivers
