Datasheet LPV511MG/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 27 кГц, 0.0077 В/мкс, SC-70-5 — Даташит
Наименование модели: LPV511MG/NOPB
46 предложений от 17 поставщиков Микросхема Операционный усилитель, Operational Amplifier, Single, 1 Amplifier, 27kHz, 0.0077V/µs, 2.7V to 12V, SC-70, 5Pins | |||
LPV511MG/NOPB Texas Instruments | от 208 ₽ | ||
LPV511MG/NOPB Texas Instruments | 241 ₽ | ||
LPV511MG/NOPB Texas Instruments | от 246 ₽ | ||
LPV511MG/NOPB Texas Instruments | от 9 308 ₽ |
Описание: ИС, операционный усилитель, 27 кГц, 0.0077 В/мкс, SC-70-5
LPV511 Micropower, Rail-to-Rail Input and Output Operational Amplifier
January 2007
General Description
The LPV511 is a micropower operational amplifier that operates from a voltage supply range as wide as 2.7V to 12V with guaranteed specifications at 3V, 5V and 12V.
The LPV511 exhibits an excellent speed to power ratio, drawing only 880 nA of supply current with a bandwidth of 27 kHz. These specifications make the LPV511 an ideal choice for battery powered systems that require long life through low supply current, such as instrumentation, sensor conditioning and battery current monitoring. The LPV511 has an input range that includes both supply rails for ground and high side battery sensing applications. The LPV511 output swings within 100 mV of either rail to maximize the signal's dynamic range in low supply applications. In addition, the output is capable of sourcing 650 µA of current when powered by a 12V batt
- Тип ОУ: Low Power
- Количество усилителей: 1
- Полоса частот: 27 кГц
- Скорость нарастания: 0.0077 В/мкс
- Диапазон напряжения питания: 2.7 В ... 12 В
- Тип корпуса: SC-70
- Количество выводов: 5
