Datasheet LM348N - National Semiconductor Даташит Операционный усилитель, счетверенный GEN PURPOSE, DIP, 348 — Даташит
Наименование модели: LM348N
![]() 75 предложений от 34 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LM348N Operational Amplifier, Quad, 4 Amplifier, 1MHz, 0.5V/µs, ± 4V to ± 18V, DIP, 14Pins | |||
LM348NS Rochester Electronics | 15 ₽ | ||
LM348N STMicroelectronics | 26 ₽ | ||
LM348N National Semiconductor | по запросу | ||
LM348N.. STMicroelectronics | по запросу |
Описание: Операционный усилитель, счетверенный GEN PURPOSE, DIP, 348
LM148/LM248/LM348 Series Quad 741 Op Amp
November 2003
LM148/LM248/LM348 Quad 741 Op Amps
General Description
The LM148 series is a true quad 741.
It consists of four independent, high gain, internally compensated, low power operational amplifiers which have been designed to provide functional characteristics identical to those of the familiar 741 operational amplifier. In addition the total supply current for all four amplifiers is comparable to the supply current of a single 741 type op amp. Other features include input offset currents and input bias current which are much less than those of a standard 741. Also, excellent isolation between amplifiers has been achieved by independently biasing each amplifier and using layout techniques which minimize thermal coupling. The LM148 can be used anywhere multiple 741 or 1558 type amplifiers are being used and in applications where amplifier matching or high packing density is required. For lower power refer to LF444.
- Тип ОУ: Low Power
- Количество усилителей: 4
- Полоса частот: 1 МГц
- Скорость нарастания: 0.5 В/мкс
- Диапазон напряжения питания: ± 4 В ... ± 18 В
- Тип корпуса: DIP
- Количество выводов: 14
- SVHC: No SVHC (15-Dec-2010)
- Тип усилителя: High Gain Operational
- Семейство: 348
- Добротность: 1 МГц
- IC Generic Number: 348
- Рабочий диапазон температрур: Commercial
- Напряжение смещения входа максимальное: 6 мВ
- Количество логических функций: 348
- Напряжение питания (+) номинальное: 15 В
- Способ монтажа: Through Hole
Дополнительные аксессуары:
- Fischer Elektronik - ICK 14/16 B
- Fischer Elektronik - ICK 14/16 L
- Fischer Elektronik - WLK 5
