Datasheet Intersil HI5860 — Даташит
Производитель | Intersil |
Серия | HI5860 |
12-битный, 130 MSPS, высокоскоростной цифро-аналоговый преобразователь
![]() 25 предложений от 22 поставщиков Цифро-аналоговые преобразователи (ЦАП) 12-BIT D/A 130MSPS 2 8LD IND TEMP | |||
HI5860IBZ-T Intersil | 750 ₽ | ||
HI5860_05 Intersil | по запросу | ||
HI5860IBZ | по запросу | ||
HI5860S0ICEVALI Intersil | по запросу |
HI5860IA | HI5860IA-T | HI5860IB | HI5860IBZ | HI5860IBZ-T | |
N | 1 | 2 | 3 | 4 | 5 |
Корпус | 28 Ld TSSOP | 28 Ld TSSOP T+R | 28 Ld SOIC | 28 Ld SOIC | 28 Ld SOIC T+R |
Parameters / Models | HI5860IA | HI5860IA-T | HI5860IB | HI5860IBZ | HI5860IBZ-T |
± DNL (Diff. Non-Linearity) (LSB) | 1 | 1 | 1 | 1 | 1 |
± INL (Integral Non-Linearity) (LSB) | 2 | 2 | 2 | 2 | 2 |
Description | 12-Bit, 130 MSPS, High Speed D/A Converter | 12-Bit, 130 MSPS, High Speed D/A Converter | 12-Bit, 130 MSPS, High Speed D/A Converter | 12-Bit, 130 MSPS, High Speed D/A Converter | 12-Bit, 130 MSPS, High Speed D/A Converter |
Max Conv Rate (MSPS) | 130 | 130 | 130 | 130 | 130 |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Output I/V | I | I | I | I | I |
Peak Temp | 240°C | 240°C | 240°C | 260°C | 260°C |
Power (mW) | 32mW at 100Msps (3V) | 32mW at 100Msps (3V) | 32mW at 100Msps (3V) | 32mW at 100Msps (3V) | 32mW at 100Msps (3V) |
Qualification Level | Standard | Standard | Standard | Standard | Standard |
Разрешение | 12 | 12 | 12 | 12 | 12 |
SFDR (typ) to Nyquist (dBc) | 76dBc 2.5MHz@50Msps | 76dBc 2.5MHz@50Msps | 76dBc 2.5MHz@50Msps | 76dBc 2.5MHz@50Msps | 76dBc 2.5MHz@50Msps |
VREF | Int/Ext | Int/Ext | Int/Ext | Int/Ext | Int/Ext |
VS (max) | 5 V | 5 V | 5 V | 5 V | 5 V |
VS (min) | 3 V | 3 V | 3 V | 3 V | 3 V |
В± DNL (Diff. Non-Linearity) (LSB) | 1 | 1 | 1 | 1 | 1 |
В± INL (Integral Non-Linearity) (LSB) | 2 | 2 | 2 | 2 | 2 |
Серия: HI5860 (5)
- Data Converters > D/A Converters > D/A Converters
