Datasheet Intersil ISL5861 — Даташит
ПроизводительIntersil
СерияISL5861
12-битный, +3,3 В, 210/130 MSPS, высокоскоростной цифро-аналоговый преобразователь CommLink
ISL5861 Datasheet
PDF, 967 Кб, Версия: 31-10-2017
19 предложений от 19 поставщиков
Микросхема Преобразователь DA, DAC 1CH Segment 12Bit 28Pin TSSOP
ISL5861IB
Intersil
409 ₽
Элитан
ISL5861IB
Renesas
1 121 ₽
ISL5861EVAL2
Renesas
ISL5861/2IB
Intersil
ISL5861/2IAISL5861/2IAZISL5861/2IBISL5861/2IBZISL5861IAISL5861IAZISL5861IBISL5861IBZ
N12345678
Корпус28 Ld TSSOP28 Ld TSSOP28 Ld SOIC28 Ld SOIC28 Ld TSSOP28 Ld TSSOP28 Ld SOIC28 Ld SOIC
Parameters / ModelsISL5861/2IAISL5861/2IAZISL5861/2IBISL5861/2IBZISL5861IAISL5861IAZISL5861IBISL5861IBZ
± DNL (Diff. Non-Linearity) (LSB)11111111
± INL (Integral Non-Linearity) (LSB)1.251.251.251.251.251.251.251.25
Description12-Bit, +3.3V, 210/130MSPS, CommLink? High Speed D/A Converter12-Bit, +3.3V, 210/130MSPS, CommLink? High Speed D/A Converter12-Bit, +3.3V, 210/130MSPS, CommLink? High Speed D/A Converter12-Bit, +3.3V, 210/130MSPS, CommLink? High Speed D/A Converter12-Bit, +3.3V, 210/130MSPS, CommLink? High Speed D/A Converter12-Bit, +3.3V, 210/130MSPS, CommLink? High Speed D/A Converter12-Bit, +3.3V, 210/130MSPS, CommLink? High Speed D/A Converter12-Bit, +3.3V, 210/130MSPS, CommLink? High Speed D/A Converter
Max Conv Rate (MSPS)210, 130210, 130210, 130210, 130210, 130210, 130210, 130210, 130
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Output I/VIIIIIIII
Peak Temp240°C260°C240°C260°C240°C260°C240°C260°C
Power (mW)110mW at 200Msps110mW at 200Msps110mW at 200Msps110mW at 200Msps110mW at 200Msps110mW at 200Msps110mW at 200Msps110mW at 200Msps
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandard
Разрешение1212121212121212
SFDR (typ) to Nyquist (dBc)73dBc 10MHz@130Msps73dBc 10MHz@130Msps73dBc 10MHz@130Msps73dBc 10MHz@130Msps73dBc 10MHz@130Msps73dBc 10MHz@130Msps73dBc 10MHz@130Msps73dBc 10MHz@130Msps
VREFInt/ExtInt/ExtInt/ExtInt/ExtInt/ExtInt/ExtInt/ExtInt/Ext
VS (max)3.6 V3.6 V3.6 V3.6 V3.6 V3.6 V3.6 V3.6 V
VS (min)2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V
В± DNL (Diff. Non-Linearity) (LSB)11111111
В± INL (Integral Non-Linearity) (LSB)1.251.251.251.251.251.251.251.25
RoHSСовместимСовместимСовместимСовместим
  • Data Converters > D/A Converters > D/A Converters
На английском языке: Datasheet Intersil ISL5861
