Datasheet Intersil ISL5761 — Даташит
| Производитель | Intersil |
| Серия | ISL5761 |
10-битный, +3,3 В, 210/130 MSPS, высокоскоростной цифро-аналоговый преобразователь CommLink
Купить ISL5761 на РадиоЛоцман.Цены — от 63 до 767 ₽19 предложений от 19 поставщиков Микросхема Преобразователь DA, 10Bit, 3.3V, 130/210MSPS, High Speed D/A Converter | |||
| ISL5761IAZ | 222 ₽ | ||
| ISL5761/21A Rochester Electronics | 258 ₽ | ||
| ISL5761IAZ Intersil | по запросу | ||
| ISL5761/2IB Intersil | по запросу | ||
| ISL5761/2IA | ISL5761/2IAZ | ISL5761/2IB | ISL5761/2IBZ | ISL5761IA | ISL5761IAZ | ISL5761IB | ISL5761IBZ | |
| N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
| Корпус | 28 Ld TSSOP | 28 Ld TSSOP | 28 Ld SOIC | 28 Ld SOIC | 28 Ld TSSOP | 28 Ld TSSOP | 28 Ld SOIC | 28 Ld SOIC |
| Parameters / Models | ISL5761/2IA | ISL5761/2IAZ | ISL5761/2IB | ISL5761/2IBZ | ISL5761IA | ISL5761IAZ | ISL5761IB | ISL5761IBZ |
| ± DNL (Diff. Non-Linearity) (LSB) | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 |
| ± INL (Integral Non-Linearity) (LSB) | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 |
| Description | 10-Bit, +3.3V, 210/130MSPS, CommLink? High Speed D/A Converter | 10-Bit, +3.3V, 210/130MSPS, CommLink? High Speed D/A Converter | 10-Bit, +3.3V, 210/130MSPS, CommLink? High Speed D/A Converter | 10-Bit, +3.3V, 210/130MSPS, CommLink? High Speed D/A Converter | 10-Bit, +3.3V, 210/130MSPS, CommLink? High Speed D/A Converter | 10-Bit, +3.3V, 210/130MSPS, CommLink? High Speed D/A Converter | 10-Bit, +3.3V, 210/130MSPS, CommLink? High Speed D/A Converter | 10-Bit, +3.3V, 210/130MSPS, CommLink? High Speed D/A Converter |
| Max Conv Rate (MSPS) | 210, 130 | 210, 130 | 210, 130 | 210, 130 | 210, 130 | 210, 130 | 210, 130 | 210, 130 |
| Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Output I/V | I | I | I | I | I | I | I | I |
| Peak Temp | 240°C | 260°C | 240°C | 260°C | 240°C | 260°C | 240°C | 260°C |
| Power (mW) | 110mW at 200Msps | 110mW at 200Msps | 110mW at 200Msps | 110mW at 200Msps | 110mW at 200Msps | 110mW at 200Msps | 110mW at 200Msps | 110mW at 200Msps |
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
| Разрешение | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
| SFDR (typ) to Nyquist (dBc) | 71dBc 10MHz@130Msps | 71dBc 10MHz@130Msps | 71dBc 10MHz@130Msps | 71dBc 10MHz@130Msps | 71dBc 10MHz@130Msps | 71dBc 10MHz@130Msps | 71dBc 10MHz@130Msps | 71dBc 10MHz@130Msps |
| VREF | Int/Ext | Int/Ext | Int/Ext | Int/Ext | Int/Ext | Int/Ext | Int/Ext | Int/Ext |
| VS (max) | 3.3 V | 3.3 V | 3.3 V | 3.3 V | 3.3 V | 3.3 V | 3.3 V | 3.3 V |
| VS (min) | 3.3 V | 3.3 V | 3.3 V | 3.3 V | 3.3 V | 3.3 V | 3.3 V | 3.3 V |
| В± DNL (Diff. Non-Linearity) (LSB) | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 |
| В± INL (Integral Non-Linearity) (LSB) | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 |
| RoHS | Совместим | Совместим | Совместим | Совместим |
Серия: ISL5761 (8)
- Data Converters > D/A Converters > D/A Converters
