Datasheet LM7301IM/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 4 МГц, 1.25 В/мкс, SOIC-8 — Даташит
Наименование модели: LM7301IM/NOPB
![]() 24 предложений от 18 поставщиков Микросхема Операционный усилитель, IC OPAMP GP 4MHz RRO 8SOIC | |||
LM7301IM/NOPB Texas Instruments | от 206 ₽ | ||
LM7301IM/NOPB Texas Instruments | 399 ₽ | ||
LM7301IM/NOPB Texas Instruments | по запросу | ||
Описание: ИС, операционный усилитель, 4 МГц, 1.25 В/мкс, SOIC-8
LM7301 Low Power, 4 MHz GBW, Rail-to-Rail Input-Output Operational Amplifier in TinyPak Package
October 29, 2010
LM7301 Low Power, 4 MHz GBW, Rail-to-Rail Input-Output Operational Amplifier in TinyPakTM Package
General Description
The LM7301 provides high performance in a wide range of applications.
The LM7301 offers greater than rail-to-rail input range, full rail-to-rail output swing, large capacitive load driving ability and low distortion. With only 0.6 mA supply current, the 4 MHz gain-bandwidth of this device supports new portable applications where higher power devices unacceptably drain battery life. The LM7301 can be driven by voltages that exceed both power supply rails, thus eliminating concerns over exceeding the common-mode voltage range. The rail-to-rail output swing capability provides the maximum possible dynamic range at the output. This is particularly important when operating on low supply voltages. Operating on supplies of 1.8V32V, the LM7301 is excellent for a v
- Тип ОУ: Low Power
- Количество усилителей: 1
- Полоса частот: 4 МГц
- Скорость нарастания: 1.25 В/мкс
- Диапазон напряжения питания: 2.2 В ... 30 В
- Тип корпуса: SOIC
- Количество выводов: 8
