Datasheet Intersil ISL5957 — Даташит
Производитель | Intersil |
Серия | ISL5957 |
14-битный, +3,3 В, 260 MSPS, высокоскоростной цифро-аналоговый преобразователь
![]() 20 предложений от 20 поставщиков Микросхема Преобразователь DA, DAC 1CH Segment 14Bit 28Pin TSSOP | |||
ISL5957IB | 1 615 ₽ | ||
ISL5957IB Intersil | 3 766 ₽ | ||
ISL5957IA | по запросу | ||
ISL5957IBZ Intersil | по запросу |
ISL5957IA | ISL5957IAZ | ISL5957IB | ISL5957IBZ | |
N | 1 | 2 | 3 | 4 |
Корпус | 28 Ld TSSOP | 28 Ld TSSOP | 28 Ld SOIC | 28 Ld SOIC |
Parameters / Models | ISL5957IA | ISL5957IAZ | ISL5957IB | ISL5957IBZ |
± DNL (Diff. Non-Linearity) (LSB) | 3 | 3 | 3 | 3 |
± INL (Integral Non-Linearity) (LSB) | 5 | 5 | 5 | 5 |
Description | 14-Bit, +3.3V, 260MSPS, High Speed D/A Converter | 14-Bit, +3.3V, 260MSPS, High Speed D/A Converter | 14-Bit, +3.3V, 260MSPS, High Speed D/A Converter | 14-Bit, +3.3V, 260MSPS, High Speed D/A Converter |
Max Conv Rate (MSPS) | 260 | 260 | 260 | 260 |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Output I/V | I | I | I | I |
Peak Temp | 240°C | 260°C | 240°C | 260°C |
Power (mW) | 157mW at 260Msps | 157mW at 260Msps | 157mW at 260Msps | 157mW at 260Msps |
Qualification Level | Standard | Standard | Standard | Standard |
Разрешение | 14 | 14 | 14 | 14 |
SFDR (typ) to Nyquist (dBc) | 75dBc 10MHz@130Msps | 75dBc 10MHz@130Msps | 75dBc 10MHz@130Msps | 75dBc 10MHz@130Msps |
VREF | Int/Ext | Int/Ext | Int/Ext | Int/Ext |
VS (max) | 3.6 V | 3.6 V | 3.6 V | 3.6 V |
VS (min) | 2.7 V | 2.7 V | 2.7 V | 2.7 V |
В± DNL (Diff. Non-Linearity) (LSB) | 3 | 3 | 3 | 3 |
В± INL (Integral Non-Linearity) (LSB) | 5 | 5 | 5 | 5 |
Серия: ISL5957 (4)
- Data Converters > D/A Converters > D/A Converters
