Datasheet Intersil X9C102 — Даташит
ПроизводительIntersil
СерияX9C102
Потенциометр с цифровым управлением (XDCP)
X9C102, X9C103, X9C104, X9C503 Datasheet
PDF, 529 Кб, Версия: 31-10-2017
51 предложений от 27 поставщиков
Энергонезависимый цифровой потенциометр, 1 кОм, Одиночный, 3-проводной, Последовательный, Линейный
X9C102PI
Intersil
65 ₽
X9C102S
116 ₽
X9C102S
Intersil
727GS
X9C102SIT1
Intersil
X9C102PX9C102PIX9C102PIZX9C102PMX9C102PZX9C102SX9C102SIX9C102SIT1X9C102SIT2X9C102SIZX9C102SIZT1X9C102SIZT2X9C102ST1X9C102ST2X9C102SZX9C102SZT1X9C102SZT2
N1234567891011121314151617
Корпус8 Ld PDIP8 Ld PDIP8 Ld PDIPRetired - Please contact us for package data8 Ld8 Ld PDIP8 Ld SOIC8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R
Parameters / ModelsX9C102PX9C102PIX9C102PIZX9C102PMX9C102PZX9C102SX9C102SIX9C102SIT1X9C102SIT2X9C102SIZX9C102SIZT1X9C102SIZT2X9C102ST1X9C102ST2X9C102SZX9C102SZT1X9C102SZT2
# of Taps100100100100100100100100100100100100100100100100100
Количество каналов11111111111111111
DescriptionDigitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)Digitally Controlled Potentiometer (XDCP?)
Dual Supply Range (V)N/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
End-to-End Tempco (В±ppm/В°C)600600600600600600600600600600600600600600600600600
Основные особенностиIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5VIntegrated charge pump to allow for single supply to swing -5.5V to 5.5V
ICC750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA750 μA
Interface Type3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)
Max Operating Temp85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C85 °C
Memory TypeNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatileNonvolatile
Middlepoint Ratiometric Tempco2020202020202020202020202020202020
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp240°C240°C240°C240°C260°C260°C260°C240°C240°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
Resistance Options (kΩ)11111111111111111
Resistance Options (kО©)11111111111111111
Resistance TaperLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinearLinear
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V
VL Max. Terminal Voltage5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V5 V
VL Min. Terminal Voltage-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V-5 V
Wiper Current4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA4.4 mA
Wiper Resistance40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©40 О©
Интерфейс3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)3-Wire (Up/Down)
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
X9C103 X9C104 X9C503
  • Data Converters > Digital Potentiometers (DCPs) > DCPs
На английском языке: Datasheet Intersil X9C102
