Datasheet LMH6703MA/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 1.2GHZ, 4200 В/мкс, SOIC-8 — Даташит
National Semiconductor LMH6703MA/NOPB
Наименование модели: LMH6703MA/NOPB
31 предложений от 18 поставщиков
Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMH6703MA/NOPB Operational Amplifier, Single, 1 Amplifier, 1.2GHz, 4200V/µs, ± 4V to ± 6V, SOIC, 8Pins
T-electron
LMH6703MA/NOPB
162 ₽
LMH6703MA/NOPB
288 ₽
IC Home
LMH6703MA/NOPB
375 ₽
LMH6703MA/NOPB
426 ₽
Описание: ИС, операционный усилитель, 1.2GHZ, 4200 В/мкс, SOIC-8
data sheetСкачать Data Sheet
LMH6703 1.2 GHz, Low Distortion Op Amp with Shutdown
May 2005
General Description
The LMHTM6703 is a very wideband, DC coupled monolithic operational amplifier designed specifically for ultra high resolution video systems as well as wide dynamic range systems requiring exceptional signal fidelity.
Benefiting from National's current feedback architecture, the LMH6703 offers a practical gain range of ± 1 to ± 10 while providing stable operation without external compensation, even at unity gain. At a gain of +2 the LMH6703 supports ultra high resolution video systems with a 750 MHz 2 VPP -3 dB Bandwidth. With 12-bit distortion levels through 10 MHz (RL = 100), and a input referred noise, the LMH6703 is the ideal 2.3nV/ driver or buffer for high speed flash A/D and D/A converters. Wide dynamic range systems such as radar and communication receivers requiring a wideband amplifier offering exceptional signal purity will find the LMH6703'
  • Тип ОУ: Low Distortion
  • Количество усилителей: 1
  • Полоса частот: 1.2GHz
  • Скорость нарастания: 4200 В/мкс
  • Диапазон напряжения питания: ± 4 В ... ± 6 В
  • Тип корпуса: SOIC
  • Количество выводов: 8
На английском языке: Datasheet LMH6703MA/NOPB - National Semiconductor IC, OP-AMP, 1.2GHZ, 4200 V/µs, SOIC-8
