Оптопары и оптореле Megawin
Datasheet LM380N - National Semiconductor Даташит ИС, усилитель, аудио 2.0 Вт, DIP14, 380 — Даташит
National Semiconductor LM380N
Наименование модели: LM380N
56 предложений от 28 поставщиков
Микросхема Усилитель звуковой частоты, Audio Power Amplifier, AB, 1Channel, 2W, 10V to 22V, DIP, 14Pins
LM380N
82 ₽
LM380N-8/NOPB
от 177 ₽
ЗУМ-СМД
LM380N
2-LM380N
Описание: ИС, усилитель, аудио 2.0 Вт, DIP14, 380
data sheetСкачать Data Sheet
LM380 2.5W Audio Power Amplifier
August 2000
General Description
The LM380 is a power audio amplifier for consumer applications.
In order to hold system cost to a minimum, gain is internally fixed at 34 dB. A unique input stage allows ground referenced input signals. The output automatically selfcenters to one-half the supply voltage. The output is short circuit proof with internal thermal limiting. The package outline is standard dual-in-line. The LM380N uses a copper lead frame. The center three pins on either side comprise a heat sink. This makes the device easy to use in standard PC layouts. Uses include simple phonograph amplifiers, intercoms, line drivers, teaching machine outputs, alarms, ultrasonic drivers, TV sound systems, AM-FM radio, small servo drivers, power converters, etc. A selected part for more power on higher supply voltages is available as the LM384. For more information see AN-69.
  • Количество каналов: 1
  • Output Power: 2 Вт
  • Диапазон напряжения питания: 10 В ... 22 В
  • THD + N: 0.2% @ VS=18V
  • Load Impedance: 8 Ом
  • Amplifier Case Style: DIP
  • Количество выводов: 14
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: DIP
  • Amplifier Type: Power
  • Bandwidth: 0.1 МГц
  • Семейство: 380
  • Маркировка: LM380N
  • IC Generic Number: 380
  • Рабочий диапазон температрур: Commercial
  • Load Impedance Min: 8 Ом
  • Количество логических функций: 380
  • Number of Amplifiers: 1
  • Operational Amplifier Features: аудио
  • Output Power Pout: 2.5 Вт @ 8 Ом
  • Power Rating RMS: 2.5 Вт
  • Supply Voltage + Nom: 18 В
На английском языке: Datasheet LM380N - National Semiconductor IC, AMP, AUDIO 2.0 W, DIP14, 380
