Datasheet LM384N - National Semiconductor Даташит ИС, усилитель, аудио 5.0 Вт, DIP14, 384 — Даташит
Наименование модели: LM384N
Описание: ИС, усилитель, аудио 5.0 Вт, DIP14, 384
LM384 5W Audio Power Amplifier
August 2000
General Description
The LM384 is a power audio amplifier for consumer applications.
In order to hold system cost to a minimum, gain is internally fixed at 34 dB. A unique input stage allows ground referenced input signals. The output automatically selfcenters to one-half the supply voltage. The output is short-circuit proof with internal thermal limiting. The package outline is standard dual-in-line. A copper lead frame is used with the center three pins on either side comprising a heat sink. This makes the device easy to use in standard p-c layout. Uses include simple phonograph amplifiers, intercoms, line drivers, teaching machine outputs, alarms, ultrasonic drivers, TV sound systems, AM-FM radio, sound projector systems, etc. See AN-69 for circuit details.
- Amplifier Class: AB
- Количество каналов: 1
- Output Power: 5 Вт
- Диапазон напряжения питания: 12 В ... 26 В
- THD + N: 0.25% @ 4 Вт, 8 Ом
- Load Impedance: 8 Ом
- Amplifier Case Style: DIP
- Количество выводов: 14
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: DIP
- Amplifier Type: Power
- Bandwidth: 0.45 МГц
- Семейство: 384
- IC Generic Number: 384
- Рабочий диапазон температрур: Commercial
- Load Impedance Min: 8 Ом
- Количество логических функций: 384
- Number of Amplifiers: 1
- Operational Amplifier Features: аудио
- Output Power Pout: 5.5 Вт @ 8 Ом
- Power Rating RMS: 5.5 Вт
- Supply Voltage + Nom: 22 В
- Способ монтажа: Through Hole
