Datasheet LM3876T - National Semiconductor Даташит усилитель, аудио + MUTE 100 Вт, 3876, SIL-11 — Даташит
Наименование модели: LM3876T
![]() 18 предложений от 16 поставщиков Микросхема Усилитель звуковой частоты, Audio Amp Speaker 1CH Mono 56W Class-B 11Pin(11+Tab) TO-220 Tube | |||
LM3876T National Semiconductor | 274 ₽ | ||
LM3876T SIP11 NSC | 2 285 ₽ | ||
LM3876T National Semiconductor | по запросу | ||
LM3876T/NOPB Texas Instruments | по запросу |
Описание: Усилитель, аудио + MUTE 100 Вт, 3876, SIL-11
LM3876 Overture Audio Power Amplifier Series High-Performance 56W Audio Power Amplifier w/Mute
August 2000
LM3876 OvertureTM Audio Power Amplifier Series High-Performance 56W Audio Power Amplifier w/Mute
General Description
The LM3876 is a high-performance audio power amplifier capable of delivering 56W of continuous average power to an 8 load with 0.1% THD+N from 20Hz20kHz.
The performance of the LM3876, utilizing its Self Peak Instantaneous Temperature (°Ke) (SPiKeTM) protection circuitry, puts it in a class above discrete and hybrid amplifiers by providing an inherently, dynamically protected Safe Operating Area (SOA). SPiKe protection means that these parts are completely safeguarded at the output against overvoltage, undervoltage, overloads, including shorts to the supplies, thermal runaway, and instantaneous temperature peaks. The LM3876 maintains an excellent signal-to-noise ratio of greater than 95dB (min) with a typical low noise floor of 2.0µV. It exhibits extremely low TH
- Amplifier Class: B
- Количество каналов: 1
- Output Power: 56 Вт
- Диапазон напряжения питания: 24 В ... 84 В
- THD + N: 0.06% @ 40 Вт, 8 Ом, V=35V
- Load Impedance: 8 Ом
- Amplifier Case Style: TO-220
- Количество выводов: 11
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: TO-220
- Amplifier Type: Power
- Bandwidth: 8 МГц
- Семейство: 3876
- Маркировка: LM3876T
- IC Generic Number: 3876
- Input Offset Voltage Max: 15mV
- Load Impedance Min: 8 Ом
- Количество логических функций: 3876
- Number of Amplifiers: 1
- Рабочий диапазон температрур: -20°C ... +85°C
- Operational Amplifier Features: аудио
- Output Power Pout: 56 Вт @ 8 Ом
- Power Rating RMS: 56 Вт
- Slew Rate: 11
- Supply Voltage + Nom: 35 В
- Способ монтажа: Through Hole
