Datasheet Intersil X9C103 — Даташит
Производитель | Intersil |
Серия | X9C103 |
Потенциометр с цифровым управлением (XDCP)
![]() 52 предложений от 27 поставщиков Модуль цифрового потенциометра на чипе X9C103S (до 10 кОм). Модуль может запоминать последнее значение сопротивления в EEPROM.Выходы VL, VW, VH модуля... | |||
X9C103SIT1 Intersil | 50 ₽ | ||
X9C103SIT2 Intersil | от 118 ₽ | ||
X9C103S Rochester Electronics | 285 ₽ | ||
X9C103PZ Renesas | от 1 284 ₽ |
X9C103P | X9C103PI | X9C103PIZ | X9C103PM | X9C103PZ | X9C103S | X9C103SI | X9C103SIT1 | X9C103SIT2 | X9C103SIZ | X9C103SIZT1 | X9C103SIZT2 | X9C103ST1 | X9C103ST2 | X9C103SZ | X9C103SZT1 | X9C103SZT2 | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 |
Корпус | 8 Ld PDIP | 8 Ld PDIP | 8 Ld PDIP | Retired - Please contact us for package data8 Ld | 8 Ld PDIP | 8 Ld SOIC | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R |
Parameters / Models | X9C103P | X9C103PI | X9C103PIZ | X9C103PM | X9C103PZ | X9C103S | X9C103SI | X9C103SIT1 | X9C103SIT2 | X9C103SIZ | X9C103SIZT1 | X9C103SIZT2 | X9C103ST1 | X9C103ST2 | X9C103SZ | X9C103SZT1 | X9C103SZT2 |
# of Taps | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Description | Digitally Controlled Potentiometer (XDCP?) | Digitally Controlled Potentiometer (XDCP?) | Digitally Controlled Potentiometer (XDCP?) | Digitally Controlled Potentiometer (XDCP?) | Digitally Controlled Potentiometer (XDCP?) | Digitally Controlled Potentiometer (XDCP?) | Digitally Controlled Potentiometer (XDCP?) | Digitally Controlled Potentiometer (XDCP?) | Digitally Controlled Potentiometer (XDCP?) | Digitally Controlled Potentiometer (XDCP?) | Digitally Controlled Potentiometer (XDCP?) | Digitally Controlled Potentiometer (XDCP?) | Digitally Controlled Potentiometer (XDCP?) | Digitally Controlled Potentiometer (XDCP?) | Digitally Controlled Potentiometer (XDCP?) | Digitally Controlled Potentiometer (XDCP?) | Digitally Controlled Potentiometer (XDCP?) |
Dual Supply Range (V) | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
End-to-End Tempco (В±ppm/В°C) | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 |
Основные особенности | Integrated charge pump to allow for single supply to swing -5.5V to 5.5V | Integrated charge pump to allow for single supply to swing -5.5V to 5.5V | Integrated charge pump to allow for single supply to swing -5.5V to 5.5V | Integrated charge pump to allow for single supply to swing -5.5V to 5.5V | Integrated charge pump to allow for single supply to swing -5.5V to 5.5V | Integrated charge pump to allow for single supply to swing -5.5V to 5.5V | Integrated charge pump to allow for single supply to swing -5.5V to 5.5V | Integrated charge pump to allow for single supply to swing -5.5V to 5.5V | Integrated charge pump to allow for single supply to swing -5.5V to 5.5V | Integrated charge pump to allow for single supply to swing -5.5V to 5.5V | Integrated charge pump to allow for single supply to swing -5.5V to 5.5V | Integrated charge pump to allow for single supply to swing -5.5V to 5.5V | Integrated charge pump to allow for single supply to swing -5.5V to 5.5V | Integrated charge pump to allow for single supply to swing -5.5V to 5.5V | Integrated charge pump to allow for single supply to swing -5.5V to 5.5V | Integrated charge pump to allow for single supply to swing -5.5V to 5.5V | Integrated charge pump to allow for single supply to swing -5.5V to 5.5V |
ICC | 750 μA | 750 μA | 750 μA | 750 μA | 750 μA | 750 μA | 750 μA | 750 μA | 750 μA | 750 μA | 750 μA | 750 μA | 750 μA | 750 μA | 750 μA | 750 μA | 750 μA |
Interface Type | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) |
Max Operating Temp | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C |
Memory Type | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile |
Middlepoint Ratiometric Tempco | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Peak Temp | 240°C | 240°C | 240°C | 240°C | 260°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C | 260°C | |||||
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
Resistance Options (kΩ) | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Resistance Options (kО©) | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Resistance Taper | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear |
VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VCC (min) | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V |
VL Max. Terminal Voltage | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V | 5 V |
VL Min. Terminal Voltage | -5 V | -5 V | -5 V | -5 V | -5 V | -5 V | -5 V | -5 V | -5 V | -5 V | -5 V | -5 V | -5 V | -5 V | -5 V | -5 V | -5 V |
Wiper Current | 4.4 mA | 4.4 mA | 4.4 mA | 4.4 mA | 4.4 mA | 4.4 mA | 4.4 mA | 4.4 mA | 4.4 mA | 4.4 mA | 4.4 mA | 4.4 mA | 4.4 mA | 4.4 mA | 4.4 mA | 4.4 mA | 4.4 mA |
Wiper Resistance | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© |
Интерфейс | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) | 3-Wire (Up/Down) |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: X9C103 (17)
- Data Converters > Digital Potentiometers (DCPs) > DCPs
