Datasheet LM380N/NOPB - National Semiconductor Даташит ИС, аудио PWR усилитель, CLASS AB, 2.5 Вт DIP-14 — Даташит
National Semiconductor LM380N/NOPB
Наименование модели: LM380N/NOPB
Описание: ИС, аудио PWR усилитель, CLASS AB, 2.5 Вт DIP-14
data sheetСкачать Data Sheet
LM380 2.5W Audio Power Amplifier
August 2000
General Description
The LM380 is a power audio amplifier for consumer applications.
In order to hold system cost to a minimum, gain is internally fixed at 34 dB. A unique input stage allows ground referenced input signals. The output automatically selfcenters to one-half the supply voltage. The output is short circuit proof with internal thermal limiting. The package outline is standard dual-in-line. The LM380N uses a copper lead frame. The center three pins on either side comprise a heat sink. This makes the device easy to use in standard PC layouts. Uses include simple phonograph amplifiers, intercoms, line drivers, teaching machine outputs, alarms, ultrasonic drivers, TV sound systems, AM-FM radio, small servo drivers, power converters, etc. A selected part for more power on higher supply voltages is available as the LM384. For more information see AN-69.
  • Amplifier Class: AB
  • Количество каналов: 1
  • Output Power: 2.5 Вт
  • Диапазон напряжения питания: 10 В ... 22 В
  • Load Impedance: 8 Ом
  • Рабочий диапазон температрур: 0°C ... +70°C
  • Amplifier Case Style: DIP
На английском языке: Datasheet LM380N/NOPB - National Semiconductor IC, AUDIO PWR AMP, CLASS AB, 2.5 W DIP-14
Политика конфиденциальности
