Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet LM4861M - National Semiconductor Даташит усилитель, аудио 0.5 Вт, SMD, 4861, SOIC8 — Даташит
National Semiconductor LM4861M
Наименование модели: LM4861M
Описание: Усилитель, аудио 0.5 Вт, SMD, 4861, SOIC8
data sheetСкачать Data Sheet
LM4861 1.1W Audio Power Amplifier with Shutdown Mode
February 2003
General Description
The LM4861 is a bridge-connected audio power amplifier capable of delivering 1.1W of continuous average power to an 8 load with 1% THD+N using a 5V power supply.
Boomer audio power amplifiers were designed specifically to provide high quality output power with a minimal amount of external components using surface mount packaging. Since the LM4861 does not require output coupling capacitors, bootstrap capacitors, or snubber networks, it is optimally suited for low-power portable systems. The LM4861 features an externally controlled, low-power consumption shutdown mode, as well as an internal thermal shutdown protection mechanism. The unity-gain stable LM4861 can be configured by external gain-setting resistors for differential gains of up to 10 without the use of external compensation components. Higher gains may be achieved with suitable compensa
  • Количество каналов: 1
  • Output Power: 0.5 Вт
  • Диапазон напряжения питания: 2 В ... 5.5 В
  • THD + N: 0.72% @ 1 Вт, VDD=5V
  • Load Impedance: 8 Ом
  • Amplifier Case Style: SOIC
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Amplifier Type: Power
  • Bandwidth: 0.02 МГц
  • Семейство: 4861
  • IC Generic Number: 4861
  • Load Impedance Min: 8 Ом
  • Количество логических функций: 4861
  • Number of Amplifiers: 1
  • Рабочий диапазон температрур: -20°C ... +85°C
  • Operational Amplifier Features: аудио
  • Output Power Pout: 1.1 Вт @ 8 Ом
  • Power Rating RMS: 1.1 Вт
  • Supply Voltage + Nom: 5 В
  • Способ монтажа: SMD
На английском языке: Datasheet LM4861M - National Semiconductor AMP, AUDIO 0.5 W, SMD, 4861, SOIC8
Политика конфиденциальности
