Datasheet LM1876TF - National Semiconductor Даташит усилитель, аудио DUAL 20 Вт, 1876, TO-200-15 — Даташит
Наименование модели: LM1876TF
Описание: Усилитель, аудио DUAL 20 Вт, 1876, TO-200-15
LM1876 OvertureTM Audio Power Amplifier Series Dual 20W Audio Power Amplifier with Mute and Standby Modes
July 2003
General Description
The LM1876 is a stereo audio amplifier capable of delivering typically 20W per channel of continuous average output power into a 4 or 8 load with less than 0.1% THD+N.
Each amplifier has an independent smooth transition fadein/out mute and a power conserving standby mode which can be controlled by external logic. The performance of the LM1876, utilizing its Self Peak Instantaneous Temperature (°Ke) (SPiKeTM) protection circuitry, places it in a class above discrete and hybrid amplifiers by providing an inherently, dynamically protected Safe Operating Area (SOA). SPiKe protection means that these parts are safeguarded at the output against overvoltage, undervoltage, overloads, including thermal runaway and instantaneous temperature peaks.
- Количество каналов: 2
- Output Power: 20 Вт
- Диапазон напряжения питания: 20 В ... 64 В
- THD + N: 0.009% @ 20 Вт, 8 Ом
- Load Impedance: 4 Ом
- Amplifier Case Style: TO-220
- Количество выводов: 15
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: TO-200
- Amplifier Type: Power
- Bandwidth: 7.5 МГц
- Семейство: 1876
- Маркировка: LM1876TF
- IC Generic Number: 1876
- Input Offset Voltage Max: 15mV
- Load Impedance Min: 4 Ом
- Количество логических функций: 1876
- Number of Amplifiers: 2
- Рабочий диапазон температрур: -20°C ... +85°C
- Operational Amplifier Features: аудио
- Output Power Pout: 20 Вт @ 8 Ом
- Power Rating RMS: 22 Вт
- Slew Rate: 18
- Supply Voltage + Nom: 22 В
- Способ монтажа: Through Hole
