Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet LM319M - National Semiconductor Даташит COMPARATOR DUAL, SMD, SOIC14, 319 — Даташит
National Semiconductor LM319M
Наименование модели: LM319M
Описание: COMPARATOR DUAL, SMD, SOIC14, 319
data sheetСкачать Data Sheet
LM119/LM219/LM319 High Speed Dual Comparator
August 2000
General Description
The LM119 series are precision high speed dual comparators fabricated on a single monolithic chip.
They are designed to operate over a wide range of supply voltages down to a single 5V logic supply and ground. Further, they have higher gain and lower input currents than devices like the LM710. The uncommitted collector of the output stage makes the LM119 compatible with RTL, DTL and TTL as well as capable of driving lamps and relays at currents up to 25 mA. The LM319A offers improved precision over the standard LM319, with tighter tolerances on offset voltage, offset current, and voltage gain. Although designed primarily for applications requiring operation from digital logic supplies, the LM119 series are fully specified for power supplies up to ± 15V. It features faster response than the LM111 at the expense of higher power dissipation. However, the high speed,
  • Comparator Type: High Speed
  • Number of Comparators: 2
  • Response Time: 80 нс
  • IC Output Type: DTL, RTL, TTL
  • Ток потребления: 8 мА
  • Диапазон напряжения питания: 5 В ... 36 В
  • Amplifier Case Style: SOIC
  • Количество выводов: 14
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Семейство: 319
  • Comparator Features: precision high speed dual, single monolithic chip
  • IC Generic Number: 319
  • Рабочий диапазон температрур: Commercial
  • Количество логических функций: 319
  • Output Type: TTL / DTL / RTL Compatible
  • Способ монтажа: SMD
Дополнительные аксессуары:
  • Electrolube - HTS35SL
На английском языке: Datasheet LM319M - National Semiconductor COMPARATOR DUAL, SMD, SOIC14, 319
Политика конфиденциальности
