Datasheet LM319N - National Semiconductor Даташит ИС, COMPARATOR DUAL, DIP14, 319 — Даташит
National Semiconductor LM319N
Наименование модели: LM319N
68 предложений от 34 поставщиков
IC COMPARATOR HS DUAL 14-DIP. Comparator General Purpose Open-Collector, Open-Emitter, TTL 14-DIP. Linear - Comparators
LM319N.
LM319N/NOPB
Hi-Tech Circuit Group
LM319N
LM319N
Описание: ИС, COMPARATOR DUAL, DIP14, 319
data sheetСкачать Data Sheet
LM119/LM219/LM319 High Speed Dual Comparator
August 2000
General Description
The LM119 series are precision high speed dual comparators fabricated on a single monolithic chip.
They are designed to operate over a wide range of supply voltages down to a single 5V logic supply and ground. Further, they have higher gain and lower input currents than devices like the LM710. The uncommitted collector of the output stage makes the LM119 compatible with RTL, DTL and TTL as well as capable of driving lamps and relays at currents up to 25 mA. The LM319A offers improved precision over the standard LM319, with tighter tolerances on offset voltage, offset current, and voltage gain. Although designed primarily for applications requiring operation from digital logic supplies, the LM119 series are fully specified for power supplies up to ± 15V. It features faster response than the LM111 at the expense of higher power dissipation. However, the high speed,
  • Comparator Type: High Speed
  • Number of Comparators: 2
  • Response Time: 80 нс
  • IC Output Type: DTL, RTL, TTL
  • Ток потребления: 8 мА
  • Диапазон напряжения питания: 5 В ... 36 В
  • Amplifier Case Style: DIP
  • Количество выводов: 14
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: DIP
  • Семейство: 319
  • Comparator Features: Dual High Speed
  • IC Generic Number: 319
  • Рабочий диапазон температрур: Commercial
  • Количество логических функций: 319
  • Output Type: TTL / DTL / RTL Compatible
  • Способ монтажа: SMD
На английском языке: Datasheet LM319N - National Semiconductor IC, COMPARATOR DUAL, DIP14, 319
