Datasheet Intersil X9111 — Даташит
| Производитель | Intersil |
| Серия | X9111 |
Одиночный источник питания/низкое энергопотребление/1024-Tap/шина SPI/одиночный потенциометр с цифровым управлением (XDCP)
| X9111TV14 | X9111TV14-2.7 | X9111TV14I | X9111TV14I-2.7 | X9111TV14I-2.7T1 | X9111TV14IZ | X9111TV14IZ-2.7 | X9111TV14IZ-2.7T1 | X9111TV14Z | X9111TV14Z-2.7 | |
| N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 |
| Корпус | 14 Ld TSSOP | 14 Ld TSSOP | 14 Ld TSSOP | 14 Ld TSSOP | 14 Ld TSSOP T+R | 14 Ld TSSOP | 14 Ld TSSOP | 14 Ld TSSOP T+R | 14 Ld TSSOP | 14 Ld TSSOP |
| Parameters / Models | X9111TV14 | X9111TV14-2.7 | X9111TV14I | X9111TV14I-2.7 | X9111TV14I-2.7T1 | X9111TV14IZ | X9111TV14IZ-2.7 | X9111TV14IZ-2.7T1 | X9111TV14Z | X9111TV14Z-2.7 |
| # of Taps | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 |
| Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| Description | Single Supply/Low Power/1024-Tap/SPI Bus/Single Digitally-Controlled (XDCP?) Potentiometer | Single Supply/Low Power/1024-Tap/SPI Bus/Single Digitally-Controlled (XDCP?) Potentiometer | Single Supply/Low Power/1024-Tap/SPI Bus/Single Digitally-Controlled (XDCP?) Potentiometer | Single Supply/Low Power/1024-Tap/SPI Bus/Single Digitally-Controlled (XDCP?) Potentiometer | Single Supply/Low Power/1024-Tap/SPI Bus/Single Digitally-Controlled (XDCP?) Potentiometer | Single Supply/Low Power/1024-Tap/SPI Bus/Single Digitally-Controlled (XDCP?) Potentiometer | Single Supply/Low Power/1024-Tap/SPI Bus/Single Digitally-Controlled (XDCP?) Potentiometer | Single Supply/Low Power/1024-Tap/SPI Bus/Single Digitally-Controlled (XDCP?) Potentiometer | Single Supply/Low Power/1024-Tap/SPI Bus/Single Digitally-Controlled (XDCP?) Potentiometer | Single Supply/Low Power/1024-Tap/SPI Bus/Single Digitally-Controlled (XDCP?) Potentiometer |
| Dual Supply Range (V) | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
| End-to-End Tempco (В±ppm/В°C) | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 |
| ICC | 3 μA | 3 μA | 3 μA | 3 μA | 3 μA | 3 μA | 3 μA | 3 μA | 3 μA | 3 μA |
| Interface Type | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI |
| Max Operating Temp | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C | 85 °C |
| Memory Type | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile | Nonvolatile |
| Middlepoint Ratiometric Tempco | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 |
| Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Peak Temp | 240°C | 240°C | 240°C | 240°C | 240°C | 260°C | 260°C | 260°C | 260°C | 260°C |
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
| Resistance Options (kΩ) | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
| Resistance Options (kО©) | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
| Resistance Taper | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear | Linear |
| VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
| VCC (min) | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V | 2.7 V |
| VL Max. Terminal Voltage | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
| VL Min. Terminal Voltage | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V | 0 V |
| Wiper Current | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA | 3 mA |
| Wiper Resistance | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© | 40 О© |
| Интерфейс | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI | SPI |
| RoHS | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: X9111 (10)
- Data Converters > Digital Potentiometers (DCPs) > DCPs
