Datasheet LMV7219M5/NOPB - National Semiconductor Даташит ИС, HIGH SPEED COMP, SINGLE, 7 нс SOT23-5 — Даташит
Наименование модели: LMV7219M5/NOPB
![]() 39 предложений от 22 поставщиков Микросхема Компаратор, TEXAS INSTRUMENTS LMV7219M5/NOPB Analog Comparator, Single, High Speed, 1, 7ns, 2.7V to 5V, SOT-23, 5Pins | |||
LMV7219M5/NOPB Texas Instruments | 70 ₽ | ||
LMV7219M5/NOPB Texas Instruments | 71 ₽ | ||
LMV7219M5/NOPB Texas Instruments | 426 ₽ | ||
LMV7219M5/NOPB Texas Instruments | по запросу |
Описание: ИС, HIGH SPEED COMP, SINGLE, 7 нс SOT23-5
LMV7219 7 nsec, 2.7V to 5V Comparator with Rail-to-Rail Output
November 2004
General Description
The LMV7219 is a low-power, high-speed comparator with internal hysteresis.
The LMV7219 operating voltage ranges from 2.7V to 5V with push/pull rail-to-rail output. This device achieves a 7ns propagation delay while consuming only 1.1mA of supply current at 5V. The LMV7219 inputs have a common mode voltage range that extends 200mV below ground, allowing ground sensing. The internal hysteresis ensures clean output transitions even with slow-moving inputs signals. The LMV7219 is available in the SC70-5 and SOT23-5 packages, which are ideal for systems where small size and low power are critical.
- Тип компаратора: High Speed
- Количество компараторов: 1
- Время отклика: 7 нс
- Тип выхода: Push Pull
- Ток потребления: 1.1 мА
- Диапазон напряжения питания: 2.7 В ... 5 В
- Amplifier Case Style: SOT-23
