Datasheet LMV7271MF - National Semiconductor Даташит COMPARATOR RAIL-RAIL I/P, POWERWISE — Даташит
Наименование модели: LMV7271MF
Купить LMV7271MF на РадиоЛоцман.Цены — от 25 до 188 ₽37 предложений от 20 поставщиков Микросхема Компаратор, TEXAS INSTRUMENTS LMV7271MF/NOPB Analog Comparator, Single, Low Power, 1, 880ns, 1.8V to 5.5V, SOT-23, 5Pins | |||
| LMV7271MF/NOPB Texas Instruments | 31 ₽ | ||
| LMV7271MF/NOPB Texas Instruments | 91 ₽ | ||
| LMV7271MF/NOPB Texas Instruments | по запросу | ||
| LMV7271MF Texas Instruments | по запросу | ||
Описание: COMPARATOR RAIL-RAIL I/P, POWERWISE
LMV7271/LMV7275/LMV7272 Single & Dual, 1.8V Low Power Comparators with Rail-to-Rail Input
September 2003
General Description
The LMV727X are rail-to-rail input low power comparators, which are characterized at supply voltage 1.8V, 2.7V and 5.0V.
They consume only 9uA supply current per channel while achieving a 800ns propagation delay. The LMV7271/LMV7275 (single) are available in SC70 and SOT23 packages. The LMV7272 (dual) is available in micro SMD package. With these tiny packages, the PC board area can be significantly reduced. They are ideal for low voltage, low power and space critical designs. The LMV7271/LMV7272 both feature a push-pull output stage which allows operation with minimum power consumption when driving a load. The LMV7275 features an open drain output stage that allows for wired-OR configurations. The open drain output also offers the advantage of allowing the output to be pu
- Тип компаратора: Low Power
- Количество компараторов: 1
- Время отклика: 880 нс
- Тип выхода: Push Pull
- Ток потребления: 9µ А
- Диапазон напряжения питания: 1.8 В ... 5.5 В
- Amplifier Case Style: SOT-23
- Количество выводов: 5
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOT-23
- Семейство: 7271
- Особенности компаратора: Rail-to-rail input, low power, Push/Pull
- IC Generic Number: 7271
- Количество логических функций: 7271
- Количество каналов: 1
- Рабочий диапазон температрур: -40°C ... +85°C
- Способ монтажа: SMD
