Datasheet LMV762MA - National Semiconductor Даташит DUAL COMPARATOR, SMD, SOIC8, 762 — Даташит
National Semiconductor LMV762MA
Наименование модели: LMV762MA
44 предложений от 21 поставщиков
LMV761/LMV762/LMV762Q Low Voltage, Precision Comparator with Push-Pull Output | IC COMP PREC W/P-POP LV 8-SOIC
LMV762MA
от 157 ₽
LMV762MA/NOPB
187 ₽
Контест
LMV762MA
201 ₽
LMV762MA/NOPB
Описание: DUAL COMPARATOR, SMD, SOIC8, 762
data sheetСкачать Data Sheet
LMV761/LMV762 Low Voltage, Precision Comparator with Push-Pull Output
July 2002
General Description
The LMV761/762 are precision comparators intended for applications requiring low noise and low input offset voltage.
The LV761 single has a shutdown pin that can be used to disable the device and reduce the supply current. The LMV761 is available in a space saving SOT23-6 or SOIC-8 package. The LMV762 dual is available in SOIC-8 or MSOP-8 package. They feature a CMOS input and Push-Pull output stage. The Push-Pull output stage eliminates the need for an external pull-up resistor. The LMV761/762 are designed to meet the demands of small size, low power and high performance required by portable and battery operated electronics. The input offset voltage has a typical value of 200µV at room temp and a 1mV limit over temp.
  • Тип компаратора: Precision
  • Количество компараторов: 2
  • Время отклика: 120 нс
  • Тип выхода: Push Pull
  • Ток потребления: 300µ А
  • Диапазон напряжения питания: 2.7 В ... 5 В
  • Amplifier Case Style: SOIC
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Семейство: 762
  • IC Generic Number: 762
  • Количество логических функций: 762
  • Рабочий диапазон температрур: -40°C ... +125°C
  • Способ монтажа: SMD
  • Communication Function: SM DUAL COMPARATOR
На английском языке: Datasheet LMV762MA - National Semiconductor DUAL COMPARATOR, SMD, SOIC8, 762
